K&N Product news
7/19/10
2010 Dodge Ram 2500 and 3500 6.7L Diesels Gain From New K&N High Flow Air Filter
For the new 2010 Dodge Ram 2500 and 3500 models equipped with the 6.7L engine, K&N can help to increase performance with its new High-Flow Air Filter™ number E-0787. These heavy duty pickups are designed for the driver in need of serious hauling capacity and towing power, and the designers at K&N stayed true to this form when engineering this new cube filter design that both increases the filtration surface area and power.
K&N’s expertly engineered air filters provide less air flow restriction than typical paper air filters, and this particular model E-0787 utilizes all available space inside the factory airbox which can increase the efficiency of the engine’s performance and provide the highest quality levels of filtration.
“Like the models we designed for the 2009 Dodge pickups, we designed the filter for heavy filtration and engine protection by incorporating 6 layers of our special filtration media instead of the standard 4 layers used in many of our filters.” says Joost Adriaans, the project manager for this filter design. This design protects the engine while still allowing your engine to breathe easier which can give your truck gains in both horsepower and torque. Horsepower and torque come in handy during every day driving and especially when hauling extra weight or towing. The easy to install drop in design makes this K&N replacement air filter a simple and ecological performance upgrade even for the hardiest of vehicles like the 2010 6.7L Dodge Rams.
K&N’s High Flow Air Filters are made from specially made cotton media instead of paper, making this air filter the last one you will ever need. This filter never needs to be replaced. The E-0787 utilizes a unique cube shaped design to fill the available area within the 2500’s and 3500’s deep airbox compartment. The filter will require cleaning every 50,000 miles under normal highway driving conditions and it will provide outstanding engine protection for the life of your vehicle no matter what jobs you have in store for your heavy duty pickup, and since it never needs to be replaced, part number E-0787 will help to reduce waste.
K&N Releases New Replacement Air Filter for the 2009, 2010 Suzuki SFV650 Gladius K&N’s research and development team has used its breakthrough air filtration technology to create the SU-6509.
The SU-6509 is an air filter that has been designed specifically for the 2009 and 2010 Suzuki SFV650 Gladius factory air box which ensures a perfect seal. A perfect seal is a critical part of reducing the amount of contaminants that are consumed by a vehicle’s engine. Using K&N’s SU-6509 air filter will enhance the performance of the Suzuki SFV650 Gladius by providing minimal restriction while providing outstanding filtration. Installing the SU-6509 does not require the rider to use any type of fuel management system on a fully stock motorcycle. This makes upgrading to a K&N air filter a breeze.
This filter is also considered eco-friendly because it is both washable and re-usable unlike most air filters that clog up landfills every time they are replaced. The SU-6509 is the last filter you will ever need to purchase for your motorcycle and it is backed by K&N’s incredible one million mile limited warranty.
Find K&N products for your vehicle using the K&N application search then use the K&N dealer search to find a K&N dealer in your part of the world.
