Ford Truck Club Forum
-   1992-1996 Ford F150
(http://www.fordtruckclub.net/forum/forumdisplay.php?f=93)
-   -   Starter wiring routing issues. (http://www.fordtruckclub.net/forum/showthread.php?t=10609)
Fordtruck1992 March 8th, 2015 02:17 PM
1 Attachment(s)
It's been two years since I've taken the engine out and the one things I can't remember is where these wires bolt on Attachment 1101
Russo2 March 8th, 2015 09:22 PM
The closest to the bottom, square ish one, goes to the frame right where that metal line is bolted in. The other end of it that's rounded more goes in a bolt on the starter as a ground.
Not sure on the positive ends, they change for your body style (I'm assuming a 92) compared to mine.
Fordtruck1992 March 8th, 2015 11:04 PM
I get where the ones to the starter go. But mostly forget which holes the grounds mount to. If I remember correctly the two on on the cross member go together could you try and get a pic of yours?
