Ford Truck Club Forum
-   1989-1992 Ford Ranger
(http://www.fordtruckclub.net/forum/forumdisplay.php?f=129)
-   -   Ignition cylinder lock (http://www.fordtruckclub.net/forum/showthread.php?t=11467)
mike091791 October 19th, 2017 07:53 PM
:halo:I have a 1990 Ranger with a worn out lock on the ignition cylinder and
I canít figure out how to remove it. All the videos I find say to push a
pin in through a hole in the bottom of the steering column. My truck has
no such hole. I removed the plastic covers, and there is no hole anywhere
around the lock in the steering column. Anyone know how to remove it?
glc October 19th, 2017 09:42 PM
You have to pull the steering wheel.
https://itstillruns.com/how-to-repla...92-ford-ranger
mike091791 October 20th, 2017 12:27 PM
If I read the article in that link correctly all it says to do is pull off
the steering wheel, then locate the pin and push it to release the
lock. I can see the back of the casing around the lock without
removing the steering wheel, there is nothing to push.
There is a removable end on top of the steering column held on
by three torx bolts, the elusive release pin must be behind it.
glc October 20th, 2017 08:52 PM
The pin is not visible unless the key is in the ON position. It's also not accessible until the wheel is pulled.
mike091791 October 21st, 2017 11:32 AM
I found it with a more careful examination.
There is a small hole, angled back towards
the driver that a allows access to the pin.
The steering wheel does not need to come off
to see or push the pin, you just have to get
at the correct angle.
Thanks for responding.
