Ford Truck Club Forum
-   2009-2014 Ford F150
(http://www.fordtruckclub.net/forum/forumdisplay.php?f=167)
-   -   osu ford (http://www.fordtruckclub.net/forum/showthread.php?t=12117)
osu1970 January 22nd, 2019 06:22 PM
osu ford
2010 super crew f 150 replaced rear driver lock actuator and lock still does not work any ideas
glc January 22nd, 2019 06:59 PM
I assume you mean electrically, with either the master lock button or the local lock button? Can you lock and unlock it manually?
osu1970 January 23rd, 2019 02:02 PM
yes I can unlock manually I installed a new lock actuator and still nothing could there be a ground problem or master switch problem
glc January 23rd, 2019 02:14 PM
You do need to check the wiring going into the door.
osu1970 January 26th, 2019 01:22 PM
Thanks for your responces so far no luck on replacing lock actuator very low voltage coming to back door lock
osu1970 January 26th, 2019 01:25 PM
Any experiences with a blue picture on backup camera 2010 f 150 xlt.I have had one person tell me they took emblem off and bracket unplugged the harness and dialect grease on the contacts and it then worked
harrison28 January 26th, 2019 03:15 PM
Sounds like a loose connection for your camera. I would try the removal, greasing, and reconnecting the camera.
glc January 26th, 2019 06:07 PM
Wiring issue.
HANKU July 26th, 2019 06:10 AM
Decent, need to accomplish something like this with mine.
