Ford Truck Club Forum
-   Garage Talk: General Tech Talk (http://www.fordtruckclub.net/forum/forumdisplay.php?f=215)
-   -   List of Ford bellhousing patterns (http://www.fordtruckclub.net/forum/showthread.php?t=7538)
BigBlue79 September 19th, 2012 08:03 PM
Ford Flathead engine pattern
221 V8
239 V8
255 V8
Lincoln Y-block pattern
317 V8
341 V8
368 V8
Ford Y-block pattern
239 V8
256 V8
272 V8
292 V8
312 V8
Early MEL pattern (1958-1960, Same as FE)
383 V8
410 V8
430 V8
Late MEL pattern (1961-1968)
430 V8
462 V8
FE Gen 1 and Gen 2 pattern
332 V8
352 V8
360 V8
361 V8
390 V8
391 FT V8
406 v8
410 Mercury V8
427 V8
428 V8
Early Windsor V8 pattern
221 V8
260 V8
289 V8 (made before August 3, 1964) - had five bolts holding bellhousing to block
Later Windsor V8 pattern
200 I6 1978-1983 only, partial (4 of 6 bolts) pattern.
250 I6
255 V8
289 V8 - (made after August 3, 1964) - had 6 bolts holding bellhousing to block
302 Cleveland (Australia)
351 Cleveland V8 (not the 351 Cleveland M-block engine)
351 Boss
351 Cobra Jet
351 Windsor V8
400 Cleveland M-block V8 aka 400FMX (certain 1973 casting numbers D1AE and D3AE, mated to the FMX transmission)
3.8/3.9/4.2L Canadian Essex 90° V6 (RWD only)
240 I6
300 I6
4.6L Modular V8 (first two casting runs, numbers F1AE and F2VE)
5.0L V8
5.8L V8
335/385 Big Block V8 pattern
335-Series (M-Block)
351 Modified M-block V8 (Not to be confused with the 351 Cleveland which uses the small block V8 pattern)
400 V8 (except some 1971 and 1973 late Windsor-style castings)
385-Series
370 V8
429 V8
460 V8
512 V8
Taunus pattern
1.2/1.3/1.5/1.7L Taunus V4
1.8/2.0/2.3/2.6/2.8/2.9/2.9 Cosworth/4.0L Cologne V6
Falcon Six pattern
144 I6
170 I6
200 I6 (through 1977; 1978-1983 have partial late Windsor pattern)
Early OHV Six pattern
215 I6
223 I6
262 I6
UK Essex pattern
2.0L Ford Essex V4
2.5/3.0L UK Essex V6
Pinto EAO I4 pattern
1.6L/2.0L EAO I4
Pinto OHC RWD pattern
1.3/1.6/1.8/2.0/2.3/2.5L OHC I4 RWD
Vulcan V6 pattern
2.3/2.5L HSC FWD I4
3.0L Vulcan V6 (FWD and RWD)
3.0/3.2L SHO V6
3.8L Canadian Essex 90° V6 (FWD only)
Duratec pattern
2.5/3.0/3.5L Duratec V6
3.4 DOHC SHO V8
Modular V8 pattern
4.6L SOHC/DOHC V8 (later castings, F3VE and up)
5.0L Coyote DOHC V8
5.4L SOHC/DOHC V8
6.2L Boss SOHC V8
6.8L Triton SOHC V10
BigBlue79 October 2nd, 2012 12:16 AM
I thought I'd mention for the guys just starting out in this here world of Ford trucks and cars, this list tells you what transmission/bellhousing will fit which engine, like a 351 Windsor E4OD or 302 E4OD will bolt up to the 4.2L V6's found in the 1997+ F150's.
The 400 with the dual bellhousing pattern is a rare bird nowadays, if you can find a complete engine we're talking at least $1k.
