Quantcast Vacuum Line diagram - Ford Truck Club Forum
Ford Truck Club Forum > FORD BRONCO | BRONCO II > 1980-1986 Ford Bronco
Old November 11th, 2009, 03:33 PM
GBronco's Avatar
GBronco GBronco is offline
Default Vacuum Line diagram
Hi guys, as my vacuum diagram is missing from the engine compartment, and the Haynes Manual does not cover it. Does anyone have a diagram they can send either adding it here or PM me? thanks in advance
Old November 11th, 2009, 03:37 PM
Images: 1105
Liked 14 Times in 11 Posts
Lets start with this:
VACUUM DIAGRAM ACRONYMS
A/CL: Located in the air cleaner
A/CL DV: Air Cleaner Diverter Valve
A/CL BI MET: Air Cleaner Bi-Metallic Valve
A/CL CWM: Air Cleaner Cold Weather Modulator
ACV: Air Control Valve
AIR: Ford calls this the Thermactor, short for Thermal Reactor. CA vehicles are installed with it as standard. Air Injection Reaction is what it stands for.
AIR BPV: Air Bypass Valve (aka Thermactor Air Bypass TAB)
BV: Bowl Vent (on top of the float tanks)
CARB: Carburetor
CPRV: Canister Purge Valve
DIST:
EGR: Exhaust Gas Recirculator
EFCA:
FLTR: Filter
FPR: Fuel Pressure Regulator
IVV: Thermactor Idle Vacuum Valve
MAN VAC: Indicating Manifold vacuum-Vacuum source
MAP: Manifold Absolute Pressure
SOLV: Solenoid Valve
SV-CBV: Carburetor Fuel Bowl Solenoid Vent Valve
VAC:
VCKV: Vacuum Check Valve
VRESER: Vacuum Reservoir Solenoid Valve
VRV:
V CK V: Vacuum Check Valve
VRDV: Distributor Retard Delay Valve
TVS: Throttle Valve Solenoid (aka Solepot, Dashpot)
TVV: Thermostatic Vacuum Valve (aka Ported Vacuum Switches)
PURGE CV: Vapor Canister Purge Valve
Color Codes to do Vacuum Diagram
Red = Main vacuum
Green = EGR function
Orange = Heat control Valve (exhaust & intake) (AKA heat riser but more complex)
Yellow = Distributor advance
White = EGR vacuum (source)
Black = Mainly used for the Evaporative emissions control
Black = Thermactor ACV or Diverter valve
Blue = Throttle Kicker control
Pink = Thermactor Air Bypass Valve (BPV)
Old November 11th, 2009, 03:39 PM
Senior Member
Alien Invasion Champion! Arkanoid Champion! Boxteroid Champion! Breakout Champion! Bunny Grab Champion! Cell-Out Champion! Chicken Champion! Chopper Challenge Champion! Cop-For-This Champion! Crazy Cars Champion! Crazy Koala Champion! Curveball Champion! Dick Quicks Island Adventure Champion! Disco Racer Champion! Donkey Rocket Champion! El Emigrante Champion! Flatout Minigame Champion! flyplane Champion! Girl Power Champion! Graveyard Champion! Hexxagon Champion! Ice Racer Champion! Jail Break Champion! Keg Stand Champion! Makai Grand Prix 2 Champion! Map Test Champion! Moon Lander Champion! Mystery Science Torture 3000 Champion! Navy Battles Champion! NFS Underground Champion! Parachute Panic Champion! Pin Headz Champion! Pogo Panic Champion! qmanoids Champion! Quick Shot Champion! Rally 2100 Champion! Roach Kill Champion! Ron Norths Jewels Champion! Rope Walker Champion! Rotation Champion! Run N Gun Champion! Sack Smash Champion! Shoot The Gatso Champion! Shootout Champion! Shuriken Challenge Champion! Snakeman Champion! Snowboard Slalom Champion! Sonny Sunshine Champion! Space Runner Champion! Speed Cards Champion! Spy Hunter Champion! Street Racer Champion! Submarine Champion! Summer Games Champion! Super Fishing Champion! Target Champion! TIE Fighter Shooter Champion! Turbo Turtle Champion! UFO Shoot Out Champion! War In Iraq Champion! War on Terror Champion! Weapons Of Mass Destruction Champion! What-A-Shot Champion! Witch Hunt Champion! Xmas-Boarding Champion! Zoo Keeper Champion! Bloody Seal Bounce Champion! SpongeBob Bikini Bottom Champion! Yetisports 2 - Bloody Orca Slap Champion! Spongebob Shuffleboard Champion! YetiSports 10 - The End Champion! Spongebob Snowboard Race Champion! SpongeBobs Bumper Subs Champion! Ice Age Part 4 - Ptero Glide Champion! Kim Possible Champion! SpongeBobs Pizza Toss Champion! Bubble Bobble The Rival Champion! Twelve Swap Champion! Guitar Hero 3 Champion! BM-Rex Champion! Burn Santa Burn Champion! Ed Edd n Eddy Spin Stadium Champion! Space Hunter Champion! Batman Mystery Of The Batwoman Champion! Bike Mania Champion! Bike Mania 4 Micro Office Champion! SpongeBob Squarepants Champion!
Tournaments Won: 2
More specific...which motor? got the general range of the year...80 thru 86
Old November 11th, 2009, 04:05 PM
GBronco's Avatar
Sorry, 1983 FSB with 4.9 litre and a single barrel Carter carb.
Old March 11th, 2012, 11:54 PM
big boy toys f250's Avatar
big boy toys f250 big boy toys f250 is offline
Images: 8
Default 95 f250
ive been looking for a pic of somes ones motor that shows the VACUUM lines in pics an where they might go
Old April 27th, 2012, 11:04 AM
miesk5's Avatar
miesk5 miesk5 is offline
yo,
Vacuum Line Routing Diagram in a 83 300
Source: by Michael C (collinsperformance, The Money Monster) at SuperMotors.net
this is for a FED 48 1983 4.9 motor.
http://content.chiltonsonline.com/TS...kLMs9eBQ%3d%3d
Here is my latest Vac/Emission Acronyms, Carbureted - Compiled from Seabronc (Rosie, Fred W), Seattle FSB & miesk5
Source: by miesk5
not nec. for your year/engine)
ACT: Air Charge Temperature Sensor, prior to 1992
ACTS: Air Cleaner Temperature Sensor
AIR: Thermactor, short for Thermal Reactor. CA vehicles are installed with it as standard. Air Injection Reaction is what it stands for.
AIR BPV: AIR BPV is the AIR Bypass (AIRB) Valve; also called the TAB (Thermactor Air Bypass) Valve
CARB: Carburetor
CBD: Closed Bowl Distributor
DIST: Distributor
DPFE: Differential Pressure Feedback
DV-TW:Two Way Delay Valve
EFCA: Electronic Fuel Control Assembly/ (Fuel Pressure Regulator (FPR)
EGR: Exhaust Gas Recirculation
EGRC/EGRV: EGR Vent/EGR Control
EXH HCV: Exhaust Heat Control Valve
EVP: EGR Valve Position
EGR: Valve Position
EVR: EGR Vacuum Regulator; also called EGR Vacuum Solenoid
FLTR: Filter
FPR: Fuel Pressure Regulator (check vacuum line)
HEAT VLV INT: Heat Vacuum Control Valve Intake, (next to carb)
HICV: Hot Idle Control Valve
IAT: Intake Air Temperature Sensor (Air Charge Temperature (ACT), prior to 1992
LCV: EGR Load Control
MAN VAC: Manifold vacuum-Vacuum source; usually ref. to as Vacuum Tree atop intake manifold]
PCV: Positive Crankcase Ventilation
PURGE: Vapor Canister Purge Valve
PV: Ported Vacuum
PVS: Ported Vacuum Switch (PVS) Valve
S: Spark port
SA-FV: Separator Assembly Fuel/Vacuum
SOLV: Thermactor Solenoid Valve
SV CBV: Carborator Fuel Bowl Solenoid Vent Valve
TCAC: Thermostatically Controlled Air Cleaner
TCP: Temperature Compensated Accelerator Pump
TK: Throttle Kicker
or
TVS: Temperature Vacuum Switch
TVV: Thermal Vacuum Valve
or, TVV: Thermostatic Vacuum Valve (aka Ported Vacuum Switches; Thermal Vacuum Valve)
VAC: Vacuum
VCV: Vacuum Control Valve
VDV: Vacuum Delay Valve
V CK V or VCV: Vacuum Check Valve
VOTM: Vacuum Operated Throttle Modulator
VRDV: Distributor Vacuum Delay Valve (VDV, VRDV, DV-TW)
VRDV: Vacuum Delay Valve (VDV, VRDV, DV-TW)
VRESER: Vacuum Reservoir (coffee can style in earlier years; replaced by plastic style)
VRESV REST: on earlier years such as SEABRONC's 83 is a Vacuum Restictor/delay valve, it delays vacuum for a certain amount of time
VRV: Vacuum Regulator Valve
WOT: Wide Open Throttle Valve
Many More in Standardization of All Emisson Control Parts & Names TSB 92-11-7
96 XL 5.0 E4OD, Man Xfer/Hubs
USN (Ret); 35 years...they gave me a nice Pin! & MIL/DoD Contingency Planner (semi-ret)
See my Big Bronco Links site
My SF Site
(View-All Members who have read this thread : 30
adoporto , badiggs , big boy toys f250 , BigBlue79 , bikertrash3531 , Booba5185 , Brinkmeister , Burton7.3 , Coupe302 , DoubleDee , Everhat24 , Greatblue , icepicker , jamesgang , jimmyz , JSoko , Kaotik , labford , miesk5 , muddy1977 , Patronrigo , Raleigh , RDALTON77 , Ridgerunner , RugerMeg , Russo2 , sacreno , Stephen B. , Steven2213 , tjdinmaine
valley view casino luxury line check bouxund New Member Introductions
0 July 5th, 2009 09:06 AM
diagram , line , vacuum
Powered by vBulletin® Version 3.8.6 Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
