Quantcast 96 F-150 vacuum diagram - Ford Truck Club Forum
Old May 29th, 2018, 11:09 PM
Hjsn1's Avatar
Hjsn1 Hjsn1 is offline
Default 96 F-150 vacuum diagram
Hello everyone. I'm new to the site. I signed up because I couldn't find anything online that helps me route the vacuum lines on my truck.
I've had the truck since 2001 and got into an accident. The truck has 170,000 miles on it but the engine has less than 5,000 due to an overheating issue back in ~2003. Finally got around to fixing the damage from the accident last year. It ran but had some issues that I fixed as they popped up. Had to replace the injectors last year. Then, this year, it was bogging down so I opened the hood and noticed fuel spraying all over the place. The fuel rail bolt looked like it's been broken for a long time and the smog rail that mounts right above the injectors had a crack in it and was spraying gas out of there too. I tried to get the bolt for the fuel rail out but realized that the mounting tab on the back of the lower intake manifold was broken. Off to Pull-a-Part and the second one I found wasn't broken. Got that all put together and a brand new tube installed. Now I need to correctly route the vacuum lines that deteriorated while sitting. Sorry for the long story but I figured I'd tell it all.
It's the 96 F-150 2WD. If possible, I'd like a diagram so I can get it running smoothly. And possibly more help to correctly route them.
Thanks in advance for any help you may provide.
Old May 30th, 2018, 09:55 AM
Liked 98 Times in 95 Posts
It would really help if you posted which engine and transmission you have. Makes a big difference.
Old May 30th, 2018, 04:03 PM
Hjsn1's Avatar
I'm sorry, I added all of that stuff on my profile so I thought it would show up. I have the straight 6 with a Tremec TKO 500.
(View-All Members who have read this thread : 12
cbyjim , Chayes627 , Damienr6 , frank5079 , glc , harrison28 , Hjsn1 , JeepKrusher , kdw , Kxmonster , Thom51414 , vjsimone
Easy to follow vacuum diagram for a 1991 f150 4.9i Smkaho 1973-1991 Ford F150
1 March 19th, 2018 08:23 AM
Vacuum Line Diagram Schematic needed for 2003 Ford Expedition 4x4 Eddie Bauer, 5.4L ol' T Ford Expedition 2 March 9th, 2017 10:12 AM
98 f150 v6 vacuum diagram nmorse1234 1997-2003 Ford F150
2 November 7th, 2016 04:09 PM
vacuum diagram craig 1973-1991 Ford F150
0 February 6th, 2015 05:28 AM
Vacuum Line diagram GBronco 1980-1986 Ford Bronco
9 July 13th, 2013 12:25 PM
diagram , f150 , vacuum
