Quantcast Rear brake rebuild - 87 F150 - Ford Truck Club Forum
Old May 2nd, 2013, 07:09 AM
Scorekeeper58's Avatar
Scorekeeper58 Scorekeeper58 is offline
Default Rear brake rebuild - 87 F150
I'm in the process of a rear brake rebuild for my 87 F-150, after a parking brake cable replacement project revealed a leaking wheel cylinder. The brake lines on both sides snapped off when replacing the wheel cylinders, so they get to be replaced, too. The fittings at the wheel cylinders are 5/16, but are 3/8 at the center hose that drops down from the frame. Does that sound right, or do I have an incorrect part somewhere? The new wheel cylinders were the same as the old ones, so I don't think they are the problem. Any good suggestions for engineering a solution?
I'd call it an Ugly Ford Truck, but there is no such thing.
Old May 2nd, 2013, 04:44 PM
Something sounds wrong, I used 3/8ths fittings the whole way across my truck front to back except for the master cylinder fittings, they are considerably larger, but use the same ID line. What wheel cylinders did you get?
Old May 2nd, 2013, 07:24 PM
Dorman replacements from RockAuto. Part numbers W59240 and W59241.
By the way, where in PA are you? I just moved from York to Lancaster County.
Old May 2nd, 2013, 11:38 PM
Cambria county, good ways northwest of you.
I'm not sure why you are having an issue with the fitting size, the replacements I got from carquest bolted right in and even up to one ton dually cylinders they fitting is the same size. The part numbers come up with the right part.
Old May 3rd, 2013, 06:48 AM
I've done a little more research this morning. Both the AutoZone and Advance Auto websites specify a 3/8 inlet on the wheel cylinders. It appears that the Dorman/Rock Auto parts might be the problem.
It appears that I have some more checking to do. Good thing it's going to be a nice weekend.
Old May 6th, 2013, 06:37 AM
I went back to recheck everything before I started buying more parts. As it turns out, I had mis-measured the wheel end fitting on my brake lines. It's a 3/8 fitting, and the larger one that came off the center hose is 7/16. The Rock Auto/Dorman parts are fine, they're not the problem. The oddball part is the center hose. One side is a 7/16 fitting, the other is 3/8. I checked the AutoZone and Advance websites and confirmed that is the correct measurements. I picked up an adapter and got everything put back together over the weekend. Next step is to bleed the system.
87_f150_302 , ASwaff400 , Booba5185 , catmechanic07 , elwray , F100Chief , glc , Hazzardousmat , joe250 , JSoko , ktm126 , rivahmon , Russo2 , Scorekeeper58 , skatebowd , windigowolf
'77 F150 4x4 brake upgrade ThunderTruck 1973-1991 Ford F150
4 November 26th, 2014 08:27 AM
F150 rebuild Smihshooter 1992-1996 Ford F150
3 February 20th, 2013 11:21 PM
1985 F150 Rebuild thread BigBlue79 1973-1991 Ford F150
74 March 10th, 2012 12:55 AM
Four wheeler's 1992 f150 rebuild Russo2 1992-1996 Ford F150
4 February 15th, 2012 02:58 PM
1995 F150 302 REBUILD parts pics nine5flareside 1992-1996 Ford F150
6 April 30th, 2010 09:27 AM
brake , f150 , rear , rebuild
