Quantcast throttle linkage. - Ford Truck Club Forum
Old December 16th, 2012, 11:19 PM
tmace's Avatar
tmace tmace is offline
Default throttle linkage.
Guys I need help!! I have a modified throttle linkage and I am trying to get the correct one for my truck. I have a 2150 that I wanna use opposed to my 2100. I do not have the right linkage and nothing i find is correct. It would all have to be modified. Please let me know if anyone can located one. I would prefer not to pay over $30 in total cost.
Old December 16th, 2012, 11:35 PM
Got any pics of the throttle linkage currently on your truck?
Old December 16th, 2012, 11:48 PM
tmace's Avatar
not yet. i will go take some and then post them up. but i can tell you it was a custom made linkage but i can describe it. its about 12 inches long with the OEM end and a threaded piece was welded on with an adjustable piece both sides use the same clip. i know now that the carb i had before the 2100 was put on wasnt the original one. i have a replacement carb on there temporarily it is also another 2100 with the same linkage type as my old carb. i will post pics of the carb i wanna use and the carb that is currently on my truck so you can see the issue that i am having.
Old December 16th, 2012, 11:52 PM
IIRC all the linkage for the throttle was was a piece of metal wire with a bit of metal on the end of it with a hole on the end to go on the knob on the carburetor.
Old December 16th, 2012, 11:54 PM
tmace's Avatar
yea mine is definitely not like that. its custom. if i am correct i think i need the one you are describing.
Old December 17th, 2012, 12:04 AM
I checked Broncograveyard, they're out of the anything before 1979, lemme look around on Ebay.
Old December 17th, 2012, 12:05 AM
http://www.ebay.com/itm/1970-FORD-TR...b165e5&vxp=mtr
Old December 17th, 2012, 12:11 AM
tmace's Avatar
can you find anything that is not on ebay? i have had a horrible experience with the things i have bought on there. but that is definitely the part i need. im still gonna post the pics though
Old December 17th, 2012, 12:13 AM
Okay, let me try something else..
Old December 17th, 2012, 12:15 AM
tmace's Avatar
Default Carb Pics
the first pic is the carb i wanna use and the next 2 is the set up i am currently running.
ID:	810   Click image for larger version
ID:	811   Click image for larger version
BigBlue79 , bikertrash3531 , Booba5185 , Booger , JSoko , nbfc93 , Russo2 , tmace
Linkage solution svp_evo 1973-1991 Ford F150
0 November 28th, 2012 07:56 PM
1957/60 shift linkage 3 speed vmazzoni 1948-1983 Ford F100
5 July 11th, 2012 08:15 AM
Throttle Body return spring bikertrash3531 1992-1996 Ford F150
3 June 24th, 2012 10:32 PM
04 f150 throttle body? russ94 2004-2008 Ford F150
14 August 5th, 2011 07:00 PM
shift linkage Jamesimm 1948-1983 Ford F100
2 November 3rd, 2010 03:53 PM
asap , linkage , needed , throttle
