Quantcast Surging idle, running rich, lunging at stops - Ford Truck Club Forum
Old October 7th, 2013, 06:16 PM
Default Surging idle, running rich, lunging at stops
Hey guys, been scratching my head on this and need y'alls input before I start throwing parts at it.
It seems I have developed a Surging idle. It will drop real low almost to the point of stalling, catch itself and rev back to normal. It will do this for about a minute to a minute and a half after start up.
Driving it, it is fine. Normal acceleration and cruising at any speed.
Sitting at a stop and in gear it will lunge forward against the brakes.
Have done the KOEO, KOER, and CBST. with nothing showing.
My thoughts are either O2, TPS, or IAC.
O2 isn't very old at all and I have not purchased a new IAC or TPS since owning either the 90 or 94.
Any thoughts appreciated.
Cleaned IAC, no change.
Old October 7th, 2013, 07:18 PM
MAP sensor?
Old October 7th, 2013, 08:48 PM
I don't have one. I'm MAF. I thought about that as well but I'm almost sure it would throw a code. I do know from experience that the three senors above won't necessarily throw codes if out of range. Almost as if they need total failure to do so.
Old October 7th, 2013, 11:24 PM
I'd try cleaning the MAF.
Old October 8th, 2013, 07:34 AM
Did. I think I've covered all the quick fixes. I think I might just replace the IAC and TPS for & . Then maybe the O2 if the other two don't cure it.
1992f150raptor , bikertrash3531 , dallaspoolguy , f1504x4driver , glc , Herbie , JSoko , judd94 , nflfreak43 , patrickg450 , Russo2 , yahnke
High Idle to low idle dead spot Lostin90s 1992-1996 Ford F150
3 March 15th, 2013 09:45 PM
Rich Blonde's New Car JSoko General Discussion
0 February 15th, 2013 04:04 PM
Rich Frost Smashes the Guardrail at Hot Rod Drag Week 2011 Hot Rod Magazine Hot Rod TV 0 September 14th, 2011 04:35 AM
idle rpm 95 5.0 chatterjj 1992-1996 Ford F150
3 January 3rd, 2010 08:38 AM
Woman Uses 'Because I'm Pretty' Sign To Deter Police Stops BigT67 General Discussion
40 September 12th, 2009 11:21 PM
idle , lunging , rich , running , stops , surging
