Quantcast Major power window problem, need expert. - Ford Truck Club Forum
Old July 17th, 2014, 09:55 AM
Casper's Avatar
Casper Casper is offline
Default Major power window problem, need expert.
I have a 1998 Ford F150 4.6L, I can't get the windows to work and the dome light and hood light don't work either.
I have relpaced the GEM (used), Driver widow switch, Door motor(new), replaced the acc relay(new), checked that there are no beaks in the wires from the GEM to the switch with a voltmeter (0 Ohms). I pulled all fuses even under the hood and checked them. The master switch on the drivers door is not getting any power. Makes me think its the GEM but the same problem occurs when I switch GEMs.
How do I check the GEM with a voltmeter to make sure its working?
I'm lost Now What?
Old July 18th, 2014, 09:39 PM
Images: 627
Liked 185 Times in 167 Posts
I guess nobody knows about power windows
Old July 19th, 2014, 08:11 AM
Images: 627
well Casper makes you wonder; only one other view
Old July 19th, 2014, 09:16 AM
I shall investigate and get back with ya
Old July 19th, 2014, 09:23 AM
Images: 627
i invited Casper to FTC to help solve his problem
I also invited a couple others that have asked question , but they get no response
doing this to try to get the blood flowing back in FTC
oh well, guess it is a stagnant site
Old July 19th, 2014, 10:11 AM
[QUOTE=JSoko;87027]i invited Casper to FTC to help solve his problem
if you ride into town you can find some , Scasper the ghostes that put things together with strews and boats and eat skrimps. may be they could help out
Old July 22nd, 2014, 09:08 AM
Images: 627
bump
Old July 24th, 2014, 07:59 AM
Images: 627
bump again
Old December 17th, 2014, 05:02 PM
My curiosity moves to the ground of the circuit. You could send that 12v all day and see it at the switch, but if you're not completing the circuit?
ASwaff400 , brunobruno , Casper , glc , jbrew , JSoko , KeithFoult , Klitch , MR_Pete , ncranchero , Russo2 , skatebowd
93 Flareside Mark III -Driver side power window & removal of door panel wrr3733 1992-1996 Ford F150
0 September 30th, 2013 09:32 PM
The Sargent Major bikertrash3531 General Discussion
1 December 29th, 2012 09:59 PM
2008 F350 Window And Door Lock Problem 300sflyer 2008-2010 Ford F250 | F350
5 August 28th, 2012 06:30 PM
Power Window Switch Bates88 2004-2008 Ford F150
7 August 17th, 2012 03:35 PM
major problem with truck rshirley8002 2004-2008 Ford F150
7 June 29th, 2012 02:12 PM
expert , major , power , problem , window
