Quantcast Tranny Problem - Ford Truck Club Forum
Old July 24th, 2014, 07:12 PM
willyc1's Avatar
willyc1 willyc1 is offline
Cool Tranny Problem
I have a 2005 F-150 4x4 5.4 automatic. It will go into reverse every time I try, it will sometimes go into drive or the other 3 gears, but not always, sometimes it takes going in reverse for awhile then might go into a forward gear, and seems to go into a forward gear if give it some rpm's, Once in a forward gear it goes fine, for example if I can get it going in 2nd I can keep the rpm's up and step on brake to keep it in 2nd. Any ideas out there. I'm new to this site and would appreciate any help. Thanks Willy C. P.S. It shows codes PO720 and P2106
Old July 24th, 2014, 09:26 PM
MR_Pete's Avatar
MR_Pete MR_Pete is offline
Images: 30
Liked 2 Times in 2 Posts
Hi willy, welcome to the club. Sorry to hear about your tranny problems. My next door neighbor is a tech at a local Ford dealership and I intend to try and recruit him into our club. In the mean time, I will bend his ear and see if he has any ideas on whats happening with your truck.
04 FX4 Scab 5.4
God, Guns & Guts made America Free; Let's Fight to Keep all Three
I'm a supporting member
Old July 25th, 2014, 06:49 AM
this is what my search shows up as:
P0720 - Output Speed Sensor Circuit Malfunction
symptoms
-Check Engine Light will illuminate
-Vehicle will not shift properly
-Decrease in fuel economy
-In unusual cases, there are no adverse conditions noticed by the driver
-In some cases, there may be performance problems, such as dying when coming to a stop after driving on the freeway and/or misfire-like symptoms
Common Problems That Trigger the P0720 Code
-Defective Output Speed Sensor
-Defective Shift Solenoids
-Defective Engine Coolant Temperature Sensor
-Defective Valve Body
-Dirty transmission fluid that restricts the hydraulic passages
-Defective Output Speed Sensor wiring or connector
P2106 - Throttle Actuator Control System - Forced Limited Power
Possible causes
- Throttle actuator control motor is stuck open or closed
- Faulty Throttle actuator control
- Throttle actuator control motor harness is open or shorted
- Throttle actuator control circuit poor electrical connection
ASwaff400 , BigBlue79 , Booba5185 , eff15thtee , floraflores , glc , Jrjohnson1103 , MR_Pete , OffRoadBum , Sydney , willyc1
need tranny brianmech38 1973-1991 Ford F150
1 February 14th, 2014 09:06 PM
tranny swap tmace 1948-1986 Ford F250 | F350
0 October 17th, 2013 07:20 PM
Tranny Keeps going out AWALLDD22 2004-2008 Ford F150
5 July 2nd, 2012 08:57 AM
C6 tranny Per-Arne Hauglund 1948-1986 Ford F250 | F350
1 January 25th, 2011 09:25 AM
motor and tranny ??? newbe 1948-1983 Ford F100
7 July 7th, 2010 06:25 PM
problem , tranny
