Quantcast 1992 f150 brake light issues - Ford Truck Club Forum
Old January 21st, 2015, 07:09 PM
tierney2375's Avatar
tierney2375 tierney2375 is offline
Default 1992 f150 brake light issues
I have a 1992 f150 4x4 5.0 I have an issue with my brake lights in order for my brake lights to come on the brake pedal has to be pinned to the floor.. I replaced the brake light switch but it is still the same. Anyone have any idea what else the issue could be?
Old January 21st, 2015, 07:54 PM
do you have the open end oriented correctly ?
are the wires binding ?
do you have the same style switch as the one you took out ? double check that its the right switch
should have a hole and a U-shape
did you do this
Position the switch so the U-shaped side is nearest the brake pedal and directly over/under the pin.
Slide the switch up/down trapping the power brake booster and black bushing between the switch side plates.
CAUTION: Do not substitute other types of pin retainers. Use only factory-supplied hairpin retainer.
Push the switch and power brake booster firmly toward brake pedal arm. Assembly outside white plastic washer to hairpin. Install hairpin retainer to hold entire assembly.
NOTE: the switch wire harness must have sufficient length to travel with the switch during full stroke of brake pedal . If wire length is too short, reroute as required.
1mts1 , cobra1 , glc , JSoko , ncranchero , Russo2 , tierney2375
2001-up Lightning CHMSL LED brake/cargo light GrassRoots150 Auto Parts Wanted
3 December 5th, 2012 09:56 PM
Ford BRONCO 3rd brake light install Joe'Bronco Garage Talk: Shop Class 101 9 June 10th, 2011 01:36 PM
RECON LED Smoked 3rd Brake Light Bates88 2004-2008 Ford F150
5 August 26th, 2010 08:30 PM
1992 - 1996 F150 OEM hood nine5flareside Auto Parts For Sale
0 August 3rd, 2009 08:22 PM
Painted Tail lights/3rd Brake light SS FatMan Garage Talk: Electrical & Lighting 31 June 30th, 2009 09:09 AM
1992 , brake , f150 , issues , light
