Quantcast newbie with 84 f150 VIN decode - Ford Truck Club Forum
Ford Truck Club Forum > WELCOME CENTER > New Member Introductions
Old November 24th, 2015, 02:20 PM
danny4069's Avatar
danny4069 danny4069 is offline
Default newbie with 84 f150 VIN decode
hello ford men
joined cuz i'm trying to get an old farm truck back on it's feet
im trying to decode VIN 1FTCF15F0ELA77987 (engine, carb and transmission ?)
pretty clueless as to carb prob - i'm told has a cpl of rebuilds, wont run properly help will be appreciated
Old November 25th, 2015, 01:01 PM
Liked 105 Times in 102 Posts
All you can get out of that VIN is it's a F-150 Styleside with a 302. Carb and transmission aren't in the VIN. If it's an automatic, it's a C6. If it's a stick, it could be one of several:
New Process 435
Top loaded heavy-duty 4-speed transmission with cast iron case and extension housing and aluminum shift tower. 2nd through 4th gears are synchronized with 1st and reverse using non synchronized sliding gear.
Borg Warner T-19
Top loaded heavy-duty 4-speed transmission with cast iron case and shift cover. Case casting number is 1309. Easily confused with T18, but the T19 is synchronized in all forward speeds. The T19 has a single step reverse idler gear while the T18 has a 2 step reverse idler.
T170F (Code-RUG)
Side mounted Overdrive (SMOD). Synchronized in all forward gears, with top loaded cast iron case. Used in 1978-84 Ford light duty pickups and vans. Similar in appearance to the Ford top loader transmission but has overdrive 4th gear. Three shift rails mounted to the left side of case.
T170FT (Code-RTS)
Top loaded 4 speed with 4th being overdrive. Aluminum case and shift tower. Found in Ford F100-250 light duty trucks from 1984-85, also known as a TOD (top shift overdrive)
If it's a 3 on the tree, I don't know what that would be.
The carb is a 2 barrel Motorcraft 2150 with electronic feedback.
Old November 30th, 2015, 10:30 PM
Images: 627
Liked 185 Times in 167 Posts
Welcome from Northwest Georgia
Old December 2nd, 2015, 02:32 PM
central Florida welcomes you to the club
Old December 14th, 2015, 09:08 AM
From the beautiful Gulf Coast of North West Florida, AKA the Redneck Riviera. Our membership is full of great ideas and insight . As a new member i would like to encourage you to participate in our daily site votes. which can be done by clicking on the vote icon at the top of the page.
« Hello | Hi »
danny4069 , FXRS , glc , harrison28 , JSoko , Klitch , skatebowd
78 Bronco VIN decode Al Mc 1978-1979 Ford Bronco
13 April 11th, 2018 09:20 PM
newbie with 84 f150 VIN decode danny4069 New Member Introductions 0 November 24th, 2015 02:14 PM
1980 Vin Decode Webdancer 1980-1986 Ford Bronco
5 May 13th, 2013 11:13 AM
64 F350 Data plate decode? 71429cj 1948-1986 Ford F250 | F350
3 September 11th, 2012 08:35 AM
Newbie SAS help - 97 f150 coca1 Garage Talk: Solid Axle Swaps 9 March 18th, 2011 02:05 PM
decode , f150 , newbie , vin
