Quantcast 1980 F100 Shifting Problem - Ford Truck Club Forum
Old October 31st, 2018, 03:10 PM
Steve Z's Avatar
Steve Z Steve Z is offline
Default 1980 F100 Shifting Problem
I just purchased a 1980 F100 302 v8 3-speed automatic as a project truck. I've got the engine running well, but having problems shifting. The shift lever just moves freely without engaging gears. If it randomly finds a gear, it will drive and shift ok. Obviously, the indicator doesn't work, but wasn't sure if it was a linkage problem, or what...
Any suggestions would be helpful.
Thanks.
Old October 31st, 2018, 03:17 PM
Liked 105 Times in 102 Posts
Have someone move the lever for you while you look down at the transmission and along the linkage path. This will help you tell if the problem is in the linkage or the transmission.
Old October 31st, 2018, 03:24 PM
Steve Z's Avatar
Thanks, that was my plan for this weekend. I'm assuming it is moving the linkage, in that it will find a gear randomly. If the lever is moving the linkage, any thoughts?
Old October 31st, 2018, 04:23 PM
I think that if the pointer doesn't move, the linkage may be slipping somewhere.
glc , harrison28 , JedCrone , JSoko , RustyPile , Sam442 , Steve Z
e4od tranny shifting hard moemoe3 1992-1997 Ford F250 | F350
2 September 17th, 2014 11:48 PM
F100 Transmission problem carbineone 1948-1983 Ford F100
18 October 30th, 2013 08:49 PM
Transfer Case (205) Shifting Linkage mrtief 1948-1986 Ford F250 | F350
0 October 25th, 2013 09:43 AM
Truck shifting hard Monster 2004-2008 Ford F150
4 February 1st, 2013 03:19 AM
Shifting problem? russ94 2004-2008 Ford F150
3 February 11th, 2012 10:09 PM
1980 , f100 , problem , shifting
