Quantcast Hellwig products Air Springs System - Ford Truck Club Forum
Ford Truck Club Forum > GARAGE TALK > Garage Talk: General Tech Talk
Old April 20th, 2010, 12:28 PM
Bates88's Avatar
Bates88 Bates88 is offline
Images: 146
Default Hellwig products Air Springs System
<p>Spring has sprung and theSummer is just around the corner. It's time to load up the camper and search for those fishing spots your buddies told you about. Oh wait, you need to redo the back yard first beforeyour fun in the sun can begin. So what's on your to-do list? New fence posts, a few loads of gravel, put in that new brick walkway and get rid of those dead trees. Sounds like a lot of work and hauling is going to be happening with your truck.No matter how you look at it, whether you're loading a camper or you've just loaded upfrom your tripto the local home improvement center,you're putting a major strain on your trucks rear suspension.</p>
<p>One of the things I am sure you've noticed whileyour truck was heavily loadedwas how differentlyit handled and that unsightly sag in the rear.Hellwig Products has a solution for this problemand it comes by way of their Air Spring System, also known as air bags. Their air spring system can greatly improve the control and handling of your vehicle as well as ride height while under heavy load. Air bags won't increase the load capacity, or GVWR, but what they will do is help you carry it better, smootherand more importantly,safer.</p>
<p></p>
<p>You have the ability with air bags to keep the load level by independently adjusting the air in each bag which works wellespecially with campers that generally have the water tanks on one side. Their airspring system can drastically reduce body roll and improve side to side load control, giving you better stability in cornering situations. With the use of air bags, theycan also reduce suspension fatigue from those constant heavy loads.</p>
<p>Hellwig's air bags are easy to use, simply load the vehicle, adjust thePSI of each bag to level the truck and when finished hauling release the air. The air fillers can also be mounted separately in each wheel well, which works best for campers, or at the rear license plate for easy access to both fillers at the same time.</p>
<p>All kits come complete with all parts parts needed for easy installation. The heavy duty brackets have a lifetime warranty and the air bags have a 2 year warranty. The manual fill air bags can be converted to automatic by adding an on-board air compressor and in-cab controls. For a more safe and enjoyable ride while towing and hauling check out all of Hellwig's quality products.</p>
<p>To discuss this blog entry Click Here.&lt;/p&gt;</p>
Old April 20th, 2010, 07:38 PM
My question about baggin is well, would it work with the offroad crowd or have to be removed first.
Old April 20th, 2010, 09:45 PM
Click Here.
Old April 20th, 2010, 10:47 PM
hmm well it looks like their kit is solely designed to replace coil suspension.
Old April 20th, 2010, 10:52 PM
Leaf springs stay.
(View-All Members who have read this thread : 0
There are no names to display.
Hellwig Products Sway Bar Install 1995 F150 nine5flareside Garage Talk: Brakes & Suspension 3 August 1st, 2010 10:04 PM
Cam, Springs, Rockers Clearance Question nine5flareside 1992-1996 Ford F150
7 April 17th, 2010 05:53 PM
New Release by Hellwig Products Bates88 2009-2014 Ford F150
0 March 18th, 2010 01:08 PM
Hellwig Products Sway Bars Bates88 Garage Talk: General Tech Talk 1 January 9th, 2010 03:08 PM
air , hellwig , products , spring , springs , system
