Quantcast swap to install 300 inline 6 - Ford Truck Club Forum
Ford Truck Club Forum > FORD F-250 | F-350 SERIES | SUPER DUTY > 1987-1991 Ford F250 | F350
Old December 9th, 2019, 09:49 PM
Tim's Avatar
Tim Tim is offline
Default swap to install 300 inline 6
Hello; currently my 1987 f250 has the FI 302/NP435 2WD and there's a used 300 6 non-EFI from a 1978 truck available. Not to debate the two motors yet I'd like to install the carb 300 6 yet I'm attempting to find if it's possible. I believe the engine mounts purchased online for the 1987 6cyl should fit this motor yet not sure if it'll line up with the NP435. Their are also unknown issues to me as the truck has power steering, possibly the radiator would be different, fuel tank EFI fuel pump changed out, not sure what else yet I'm curious if it's a relatively easy swap? Thanks
Old December 10th, 2019, 12:13 AM
Your biggest issue is going to be electronics. Bellhousing bolt patterns are the same, so the tranny shouldn't be a problem.
Old December 10th, 2019, 10:55 PM
Tim's Avatar
Tim Tim is offline
thanks for the information GLC, looks like it should be doable. Like that easy low end torque of the 6 for driving about and accomplishing errands : ) the 302 takes a bit of finess with the clutch otherwise
Old December 11th, 2019, 12:13 PM
You may have to change the tank. The opening for a EFI fuel pump/ sending unit is larger then on a non-EFI sending unit alone. For my swap I had to buy a 1984 tank and sending unit. I couldn't find a fuel regulator that could slow down the flow from that in tank pump.
« 1991 f250 wiring harnesses | There is no next thread »
(View-All Members who have read this thread : 4
glc , harrison28 , JSoko , Tim
CB install jones03100 1992-1996 Ford F150
5 November 3rd, 2016 05:02 AM
Federated Tech Talk - Cardone - Inline Power Steering Filter Two Guys Garage Two Guys Garage 0 February 28th, 2014 04:07 PM
1994 F150 inline 6 weak charging system davigf 1992-1996 Ford F150
6 November 6th, 2012 01:50 PM
300 inline 6 swap to 351 windsor H.O Zach Willard 1973-1991 Ford F150
14 November 4th, 2012 10:58 PM
tach install sullie1 1992-1996 Ford F150
4 January 27th, 2012 10:16 PM
300 , inline , install , swap
