Quantcast tranny issue - Ford Truck Club Forum
Old March 10th, 2013, 05:18 AM
katrobb@live.com's Avatar
katrobb@live.com katrobb@live.com is offline
Default tranny issue
will a solenoid in the trans make it not shift into drive or overdrive?
Old March 10th, 2013, 08:49 AM
Depends on the transmission you are talking about. What transmission are we dealing with?
Old March 10th, 2013, 10:04 PM
4r70w i have a 2000 f150 4.6
Old March 12th, 2013, 09:15 PM
Quick information I will quote from my transmission builder, outstanding guy if you ask me, he builds the 4r70w/4r75's for a living. I never had 3rd of 4th engage.
Note: This is an excerpt from my conversation with him regarding my truck "neutral shifting" years ago.
The way that it isn't making the shift definitely eliminates an electrical issue. If it were an electrical issue it wouldn't neutral out because the shift solenoid wouldn't energize and the transmission would stay in 2nd gear. The fact that it does neutral eliminates electrical. First gear has shift solenoid 1 on, second gear has both shift solenoids off, 3rd gear has shift solenoid 2 on and 4th gear has both ss1 and ss2 on. We know that shift solenoid 1 is working because you have first gear and we know that shift solenoid 2 is working because it neutrals out for a shift to 3rd.
Lets run with this real quick, a shift solenoid is EASY to change, but yes may be messy job. Should cost Approximately $60 to CONFIRM whether or not you are having an issue that is potentially mechanical.
Step 1: Check your WIRING HARNESS particularly where it has heat shielding and is close to the exhaust manifold.
From there we will be dropping the pan and looking, I've read about Shift solenoids failing (because they do!) as well as accumulator pistons and springs failing (under the accumulator pistons), this you may be able to spot immediately as you look up at the transmission.
Old March 13th, 2013, 10:59 PM
it will go into drive if you play with the throttle a bit then it works fine until you slow down under 20 to 30 mph
Old March 14th, 2013, 01:30 AM
Now with that im leaning towards accumulator/spring
Old March 14th, 2013, 07:20 AM
how hard is that to repair? what kind of parts are involved with that
Old March 14th, 2013, 02:03 PM
shift solenoid has a few screws holding to valve body, o-rings seal. plus electrical
accumulators are held in place with snap rings, push up, should take some effort, remove snap ring and it should come out with your guidance
I recommend you look up transgo shift kits, they should have free instructions that will explain the accumulator process.
don't forget some of the basics involved here, valve body gasket should be replaced if you drop the valve body, the filter should be replaced since you'll have it in your hands.
Old March 14th, 2013, 11:37 PM
thanks i will try that
BigBlue79 , bikertrash3531 , Booba5185 , glc , Hazzardousmat , jim austin , JonBoy , JSoko , katrobb@live.com , Klitch , nflfreak43 , Russo2 , Simple1 , windigowolf
RPM issue & starting issue rusty001 1992-1996 Ford F150
1 December 2nd, 2012 08:00 PM
tranny issues adam61484 1997-2003 Ford F150
6 October 14th, 2012 07:12 PM
Tranny Keeps going out AWALLDD22 2004-2008 Ford F150
5 July 2nd, 2012 08:57 AM
C6 tranny Per-Arne Hauglund 1948-1986 Ford F250 | F350
1 January 25th, 2011 09:25 AM
New to this, help with motor and tranny??? newbe 1966-1977 Ford Bronco
2 July 7th, 2010 05:47 PM
issue , tranny
