Quantcast Adhesive removal? - Ford Truck Club Forum
Old March 4th, 2010, 01:40 PM
2004FX4F150's Avatar
Images: 75
Default Adhesive removal?
I want to remove the Harley skull logos I added to my truck a while ago, but want to know the best way to remove the foam padding and the adhesive that is left afterwards.
On glass, windex or alcohol is the easiest way with a razor, but on paint??
Best way?
Old March 4th, 2010, 02:02 PM
check out the auto parts store. you'll find numerous products to remove the adhesive material.
back when i was putting my FX4 badge on the tailgate....I also decided to remove the dealers sticker from under the F150 badge. I just took a trip to Advance and took a look in the car care aisle. Can't remember what brand I got...but it worked.
Old March 4th, 2010, 02:28 PM
Paint is tough, if you are good, you can do it with lighter fluid, but you have to work quick. Ive removed double sided tape that wa on the truck for 15 years in anbout two minutes with lighter fluid. No paint was harmed.
Old March 4th, 2010, 02:29 PM
Images: 75
Are the aftermarket solutions on on the clearcoat? I remember Chris Duke from Motorz.tv used a wheel of some sorts on a cordless drill to remove the adhesive on one of his shows, but I have been unable to find this attachment.
I'll probably wait until it gets a little warmer out though, so it will be much easier to remove.
Old March 4th, 2010, 02:30 PM
Images: 75
I heard about that method and also WD40?
Old March 4th, 2010, 02:38 PM
WD-40 wont do anything for you. Not like lighter fluid. Get your girls blow dryer and heat that up for a few minutes, then pour some lighter fluid on it, let it soak for 30 seconds and quickly rub off. I rubbed mine off with my finger tips. Glue + paper towel = more mess.
Old March 4th, 2010, 02:41 PM
Images: 75
I'll try it next week, supposed to warm up again. I would like to remove the f150 badges, but there's damn holes that hold them in .
Old March 4th, 2010, 03:33 PM
Old Blue's Avatar
Old Blue Old Blue is offline
Images: 384
Heat gun and fingers to get the bulk of it (your finger tips will hate you)
then i used a product called goo gone on the 04 chevy i had. (removed the trim that ran down the doors) It worked pretty good.
Monthly Recognition Moderator
Check out my videos HERE
It's called an eraser wheel. Can get them at most autopart stores, not really cheap, if they are they won't last long.
Then try "Goof-Off" or goo be gone or something along those lines.
BATES
Banks & PHP Powered
Old March 4th, 2010, 03:44 PM
TedC's Avatar
TedC TedC is offline
Images: 151
Lucky thing I was a chemist in my previous life :)
I think your clearcoat is probably some type of acrylic - so you don't really want to use solvents that will dissolve this - stay away from paint thinner / mineral spirits / acetone.
The adhesive is most likely a polyvinyl alcohol based adhesive - which means an alcohol (ethanol, methanol, propanol) should do the trick on it. Likes dissolves likes (and will go into solution). Nail polish remover is a likely choice for the Propanol - methanol can usually be found in window washer fluid (allthough the concentrations are too low to have any effect on your adhesive) - ethanol in normal alcohols may work too - go high though - grain or 151. Use lot's of it - your looking to take the adhesive "into solution" before the alcohol you use can evaporate - so you can wipe both the alcohol you add + the decal right off the truck.
The foam padding is most likely styrofoam - benzene dissolves this nicely - allthough - the alcohol should soak into it and work on the adhesive - so you shouldn't need to take the foam padding off.
jamesgang
Smog Pump Removal 92 - 96 F150 nine5flareside 1992-1996 Ford F150
14 January 7th, 2011 08:42 PM
paint removal The-LI-Redneck Garage Talk: Paint & Detailing 1 April 28th, 2010 09:36 AM
Upper Bumper Pad Removal herbz 2004-2008 Ford F150
4 March 11th, 2010 01:00 PM
Spark Plug Removal instructions JSoko Garage Talk: Shop Class 101 3 July 18th, 2009 10:29 PM
adhesive , removal
