Quantcast Z-Max Fuel & Oil Additive - Ford Truck Club Forum
Old March 12th, 2010, 08:09 PM
2004FX4F150's Avatar
Images: 75
Default Z-Max Fuel & Oil Additive
Anyone have any experience with this stuff, good or bad? Thinking about picking up one of those kits.
Old March 12th, 2010, 09:15 PM
It's a micro lubricant... it will not harm your engine, however, will it improve your engines performance? I do not know the answer to that because I have never tried zMax. I had looked into zMax a few years back and found some really mixed feelings about it.
What I can tell you about everything I read is that zMax does improve fuel economy but, what you save in fuel you spend on zMax. Also, once it cycles itself out of your system, the benefits cycle out as well and your engine will be back to the state it was in prior to adding zMax.
This means you would have to continue buying zMax to keep getting the benefits of the product. Me personally, I would rather take that money and replace work items such as spark plugs, a good oil change, trans fluid change etc.
Why dont you buy some zMax and try it out. Let us know what happens. Good luck!
Old March 12th, 2010, 09:22 PM
Old Blue's Avatar
Old Blue Old Blue is offline
Images: 384
Probably not worth it in the long run but who knows
Monthly Recognition Moderator
Check out my videos HERE
Old March 13th, 2010, 11:45 AM
Images: 75
I just decided to run a can of engine restore through it, as I normally do after an oil change. And I threw a can of seafoam on the tank, maybe clean out the injectors and crap.
ANyone ever used seafoam through the vaccum lines like they say? I have no idea how to do that.
Old March 18th, 2010, 05:02 PM
Images: 75
Ran a half can of Seafoam through the brake booster vaccum line. Noticed a smoother idle and a little better pickup. Didn't experience the smoke show that everyone talks about, guess my engine wasn't that dirty.
All in all, not a bad $10.
Old March 18th, 2010, 05:09 PM
Images: 628
Liked 185 Times in 167 Posts
I think Carroll Shelby endorses it
I've never put any additives to gas or oil, ever
Old March 18th, 2010, 05:12 PM
Images: 75
It's not really the additive part that does anything, it's putting the 1/3 to 1/2 directly into the intake of the warm engine, letting it sit there for a few minutes and then restarting it. It literally cooks off all the gunk and grime.
Old March 18th, 2010, 05:19 PM
Images: 628
my engines have no gunk or grime inside or out>
Old March 26th, 2010, 05:38 PM
clockjanitor's Avatar
clockjanitor clockjanitor is offline
hmmmmmmmmmmmm.....oil
Old May 7th, 2011, 11:01 PM
Scotts Black FX4's Avatar
Images: 40
I picked up some Seafoam motor treatment and the spray for the intake system. Iam gonna dump some in the fuel tank as well. You can run the stuff in your engine until the next service. Not sure if longer is better or what...I noticed not long after I changed my oil the last time, it was already dirty again...So it must be sludged up, thought I read some Vortecs are known for that. Iam gonna go out and try the intake spray here if its not too dark yet.
95F150xlt , ASwaff400 , BigBlue79 , CrazyD , ErnieB , HawaiianF150 , JSoko , nine5flareside , nismo972 , Red91 , Russo2 , Scotts Black FX4 , tylerbotts
Replacing Fuel Filter DIXIE FIX Garage Talk: Shop Class 101 4 April 19th, 2011 07:18 AM
More on the Vegistroke Fuel Conversion TRUCK U TRUCK U 0 March 21st, 2010 02:51 PM
Killer Fuel Injection Two Guys Garage Two Guys Garage 0 January 29th, 2010 08:59 PM
Diesel Additive - Stanadyne Bates88 Garage Talk: Paint & Detailing 0 August 10th, 2009 05:52 PM
Better Fuel Mileage with O/D Off? RedHot150 2004-2008 Ford F150
65 July 15th, 2009 07:08 PM
additive , fuel , oil , zmax
