Quantcast Cab swap - Ford Truck Club Forum
Old February 13th, 2015, 06:36 PM
IrishKRO's Avatar
IrishKRO IrishKRO is offline
Images: 5
Default Cab swap
Alrighty guys, need your help and quick.
I have a 91 F150 Reg Cab 4x4. I found someone selling a 91 F250 Reg Cab 4x4 with a 460 for a grand. Can I swap the bed and cab from my F150 onto the F250? I really want the Dana 60's and the 460.
Old February 13th, 2015, 08:03 PM
the cab and bed will match up no problem, but the F250 would most likely have a dana 50 TTB front end and a sterling 10.25 or or 10.5 rear end. the F350's got a solid axle front with a dana 60 and a 10.5 out back...
Old February 13th, 2015, 09:36 PM
IrishKRO's Avatar
Images: 5
Thanks for the clarification. But either way, it's more solid than the F150 right? Also cheaper to lift. I'm not much of a fan of those twin beams up front.
Old February 14th, 2015, 12:35 AM
Bodies will swap right over. The f150 has coil sprung ttb. The 250 has leaf sprung ttb. The coil spring ttb is better, but you can 60 swap the 250 much easier than a 150. The 150 has an 8.8 rear the 250 has a 10.25
Old February 14th, 2015, 02:16 AM
IrishKRO's Avatar
Images: 5
What do you mean by coil sprung TTB is better?
Old February 14th, 2015, 12:25 PM
Liked 113 Times in 109 Posts
He's saying it's better than a leaf sprung TTB.
Old February 14th, 2015, 07:12 PM
Better than leaf sprung. The arc a ttb axle follows swings out and is and it goes up and down, leaf springs can not allow for this type of arc, the bushings don't last long and alignment gets weird after backing up. The coil springs can move in any direction so these issues aren't as prevalent.
(View-All Members who have read this thread : 9
ASwaff400 , Farm Truck 350 , glc , IrishKRO , JSoko , mn66 , Russo2 , Scorekeeper58 , stro
93 F-150 460 swap Temunds58 1992-1996 Ford F150
2 June 5th, 2013 06:11 PM
FX4 wheel swap superdutydude2 1999-2007 Ford F250 | F350
2 May 13th, 2013 03:53 AM
Cab swap Burton7.3 1992-1997 Ford F250 | F350
2 October 16th, 2012 08:08 PM
2wd to 4wd swap stromburg 1948-1986 Ford F250 | F350
1 October 9th, 2012 08:32 PM
Fusion Key Swap 2004FX4F150 Garage Talk: Shop Class 101 9 November 2nd, 2010 12:00 PM
cab , swap
