Quantcast When should I upgrade the injectors? - Ford Truck Club Forum
Old April 21st, 2010, 09:16 AM
Default When should I upgrade the injectors?
Well,
I've got the ford 302 5.0 and I am upgrading the cam, lifters, pushrods, rocker arms, manifold, throttle body. I also have headers and an exhaust system. My question is should I be upgrading my injectors from 19# to lets say 24# injectors?
At what point do you upgrade? How do you know when to upgrade? My guess is if my engine is running lean but I dont want to rebuild it just to find out!
And yes, I know that I will need a 24# MAF sensor if I upgrade to 24# injectors!
Old April 22nd, 2010, 02:30 AM
if i remember right(from other sources) 19# injectors are good for about 280 to 300 hp at the crank...
Old April 22nd, 2010, 10:07 AM
GATOR CREW's Avatar
GATOR CREW GATOR CREW is offline
Images: 19
Not sure when in your case Webby, I just know that when I added the supercharger, I went from 19# to 42# and a bigger fuel pump because I needed the fuel for the blower
Government is not the solution to our problem. Government is the problem...(Ronald Reagan)
90f150xltcenturion , Bastien , HiRoller , jared96 , Jendiump , michaelsnodgrass18 , RACERSTEVE , Russo2 , Steven Stroup , The Frankster , whitesleeper
4 July 8th, 2010 09:43 PM
92-96 Cam Upgrade nine5flareside 1992-1996 Ford F150
8 November 18th, 2009 08:39 AM
Headlight Upgrade Installation MOTORZ TV MOTORZ TV 0 August 25th, 2009 08:46 PM
Complete Brake Upgrade Installation MOTORZ TV MOTORZ TV 0 August 25th, 2009 08:45 PM
Hella Lighting Upgrade Installation MOTORZ TV MOTORZ TV 0 August 25th, 2009 08:41 PM
injectors , upgrade
