Quantcast 1990 ford bronco fullsize - Ford Truck Club Forum
Old November 7th, 2010, 10:56 PM
trfdmazzeo's Avatar
trfdmazzeo trfdmazzeo is offline
Default 1990 ford bronco fullsize
I have a 1990 ford bronco full size. 5.0 v8. rebuilt motor, tranny, and brand new transfer case. it has a 6 inch lift, sitting on 36's. it drives pretty smooth, except when under 45 mph, at a slight left bend to a full left bend (excluding full left turn) the truck starts bucking and shaking. only does it on the left.. any ideas as to why it would do that?
Old November 7th, 2010, 11:06 PM
Stock front axle?
Old November 7th, 2010, 11:10 PM
Vehicle history?
Wrecked? Axles ever rebuilt? limited slip/open rear?
That would be a TTB front end right? Have new bushings? TTB's in rangers like fresh bushings now n then after being lifted (more apt to flex)
I had a bucking issue that went away when I grenaded the 8.8 for the 4th or 5th time and swapped in a 10.5 sterling.
Old November 7th, 2010, 11:12 PM
Yes def some axle history is needed. Stab in the dark, maybe the hub is going.
Old November 7th, 2010, 11:13 PM
trfdmazzeo's Avatar
no solid front axel, not to mechanicly inclinded, it has ifs, i wana change it to sfa but idk how. no accidents, its pretty stock as far as parts wise
Old November 7th, 2010, 11:15 PM
trfdmazzeo's Avatar
Old November 7th, 2010, 11:23 PM
Upload pics to our gallery and then post them in the thread.
So you have the TTB IFS, well those axles are the worst designed of the ford axles. Def do a solid axle swap! Dana 44 or Dana 60, we can help you through it. Anyway back to the truck pulling, it could just be the front end itself. They suck and thats what they tend to do is pull, especially with the lift now and bigger tires. That thing has to be all over the road at slow speeds.
Post some pics when you get a chance, I would love to see it.
Old November 7th, 2010, 11:29 PM
its the bounce that has my eye on the bushings, radius arm bushings blow out basically over time. TTB's on lifts just adds more stress to that link.
90f150xltcenturion , alohabrewer , BIGCOUNTRY , DaveB1 , EzPcC , gale9193 , gcoxy , grayhead1 , Marinephinfan , Shade
My Bronco 2! (Bronco II) Klitch The Little Ford Bronco II
22 May 11th, 2013 11:57 AM
Bronco guy here... Joe'Bronco New Member Introductions 14 June 8th, 2011 01:49 AM
bronco big bad 79 mudman New Member Introductions 7 July 10th, 2010 03:32 AM
1985 Ford Bronco wont hold a charge DIXIE FIX 1987-1991 Ford Bronco
14 July 10th, 2010 02:17 AM
Bronco man fasterthanu1973 New Member Introductions 17 January 6th, 2010 03:44 AM
1990 , bronco , ford , fullsize
