Quantcast PCV Valve test - Ford Truck Club Forum
Old June 1st, 2011, 08:21 AM
Lightbulb PCV Valve test
Shake Your PCV Valve
Do-it-yourself and save $20
Perform the world's easiest diagnostic test: Shake your PCV valve to make sure it's working. It takes only 5 minutes to replace a bad one.
Locate your PCV Valve Some late-model Trucks & cars don't have PCV valves, so don't beat yourself up trying to find it
PCV valve replacement
Pull off the hose and remove the old valve. If it's bad, screw or push in a replacement and replace the hose.
This sounds complex, but it's not. Pull out your PCV valve every other oil change. In most cases, you'll find the valve on the top of the engine, connected to a vacuum hose. Slide the vacuum hose off the valve and unscrew or pull out the valve. Then perform the world's easiest diagnostic test: Shake it. If it makes a metallic clicking sound, it's good. If it doesn't make noise or sounds mushy, replace it. But don't replace it on appearance alone—all used PCV valves look dirty.
Need help locating your PCV valve? call or stop by the Dealer or your friendly mechanic.
90f150xltcenturion , Jendiump , JSoko , Russo2 , sbellinghausen , whitesleeper
EGR valve question... ASwaff400 1992-1996 Ford F150
1 September 21st, 2010 02:48 PM
Valve lash adjustment on a 5.0L with pedestal rockers BADSHOE BADSHOE Productions 0 March 14th, 2010 06:07 PM
Ford Racing Valve Covers chatterjj Auto Parts For Sale
4 January 7th, 2010 08:26 AM
Setting the Ford AOD Throttle Valve Cable Video BADSHOE BADSHOE Productions 1 January 5th, 2010 04:25 PM
244.00 valve covers an no pcv port chatterjj 1992-1996 Ford F150
7 January 3rd, 2010 08:43 AM
pcv , test , valve
