Quantcast Useing a Torque Wrench - Ford Truck Club Forum
Ford Truck Club Forum > GARAGE TALK > Garage Talk: The Tool Depot™
Old August 22nd, 2012, 09:13 AM
Question Useing a Torque Wrench
How to Use a Torque Wrench
A torque wrench prevents the common over-tightening problem
Buy and use a torque wrench to prevent common over-tightening problems and avoid expensive fixes later.
Advantages of a torque wrench
Torque wrench setting
Adjust the torque wrench to the manufacturer listed setting.
You may think you don’t need a torque wrench to install spark plugs or work on your lawn and garden equipment. But studies show that most DIYers overtighten just about everything. And overtightening leads to broken bolts, stripped threads and damaged equipment.
With a torque wrench and the manufacturer’s torque value in hand, the problem is solved: A “clicker” torque wrench makes an audible click when you’ve reached the set torque, and with a “beam”-style wrench, you just watch the scale and stop at the right number.
Torque Wrench Use and Care Tips
Tighten fasteners in two steps—first to half torque and then to final torque.
Clean dirty or rusted threads before tightening, but don’t lubricate them unless instructed to by the equipment manufacturer.
Always dial the wrench back to zero (never below zero) when you’re done with it.
Never use your torque wrench as a breaker bar—that’ll damage the torque mechanism.
Carry it with kid gloves—a single fall can knock the accuracy off by as much as 30 percent. If you do drop it, get it recalibrated (calibration firms listed below) before using it again.
Torque wrench calibration services
anglerepair.com. (304) 253-5729
delegardtool.com. (800) 328-2897
microprecision.com. (530) 268-1860
teamtorque.com. (888) 682-8675
Cat, uses torque wrenches bigger than a baseball bat, and watch for quality - NOT ALL TORQUE WRENCHES ARE MADE THE SAME
and he can really dive in with more info, some of the nut & bolt diameters he deals with are bigger than a softball
I remember him telling me that if you use extensions between the socket & wrench the torque value changes, so keep this in mind the next time you slip on an extension.
16 Cylinder Cummins this powers the emergency generator at one of the local hospitals, those twin turbos on top are about 22" across
when this thing fires up ya gotta plug your ears due to the high pitch whine
Big Torque Wrench used on this baby
catmechanic07 (August 22nd, 2012)
Old August 22nd, 2012, 07:30 PM
catmechanic07's Avatar
Images: 25
Liked 14 Times in 14 Posts
How do I post a pic on a single post like you did the above? Sheesh.....
I always have to resort to my Snap-On and now Mac torque wrenches. They are the best on the market by far. I have a 1/2" drive Mac that is 26" long, torque range from 50ftlb-250ftlb +/- .05, and is a clicker type. The longer the wrench.....the better just like a longer ratchet gives you more torque to remove something. I use that one to torque head bolts on Cummins, Detroits, and Cats. Cummins for instance torques to 220ftlb and then a 90 degree turn torque. 220 ftlb may not sound like much but it is a REALLY good pull! Detroit 60 Series has ( I think) 38 head bolts that has to be torqued in sequence 2x. Cat main cap bearings torque to 325ftlb then 90 degrees. Usually a 3/4 drive impact has to be used to finish the turn torque.
Here is the info on an extension: You can use an extension but try to keep it less than 6". Once you go past 6", the extension starts to twist. In theory, try removing your lugnuts with a 3/8 drive impact with a 6" extension. May do it but its vibrating bad, now try it with just the gun and a socket.....much easier and less vibration. Same thing goes for a torque wrench. The +/- variance in the wrench will give you enough play to cover for the 6" extension twisting. Another thing to remember is that impact extensions twist more than chrome extensions.
Brands: Yes....Snap-On, Mac, Matco are the best! Buy one from Harbor Freight, Advance Auto, ect......You may have stripped bolts and major repairs due to them not being "true". Its a rule of thumb to have your torque wrench calibrated every 2 years or sooner if you drop them. Also, If you leave one locked in a specific setting for more than 2 hours, unlock it and let it sit on a flat surface for no less than 2 hours. Leaving one locked for long periods of time will stretch the springs inside it and not give a true torque.
There are many types of torque wrenches. You have anything from 1/4" drive-1" drive, torque multipliers, clickers, beam, and now there are digital wrenches. The digital makes an audible beep and vibrates when the set torque is reached. You have some types that have a twist handle and some have just a flip tab to lock the setting. As Joey stated: ALWAYS set the dial back to zero and never below. If its a flip lock, some say to lock the flip back but I never do because why wouldnt that be keeping a certain amount of pressure against the internal springs? Right? The twist handle wrenches either lock when you release the handle or they have a manual lock.
Anything else??? Hmmmmmmm!
Black Sheep of FTC
Old August 22nd, 2012, 09:15 PM
add a pic to your album/gallery
click on the pic
than click on the img box below and cut then paste tp your post
as easy as useing a torque wrench
you've done it before
Bates88 , BigBlue79 , Booba5185 , catmechanic07 , JSoko , Russo2
Ingersol Rand Impact Wrench Recall HawaiianF150 Garage Talk: The Tool Depot™ 19 September 21st, 2012 07:49 AM
Rumor: Ford May Increase 2011 Super Duty Power Stroke Diesel to 800 Lb-Ft of Torque Bates88 Garage Talk: General Tech Talk 2 July 21st, 2010 04:24 PM
tranny/torque converter ? nflfreak43 1992-1996 Ford F150
10 March 14th, 2010 12:03 PM
Torque Converter and Cams HELP? nine5flareside 1992-1996 Ford F150
10 August 27th, 2009 07:55 AM
?Torque Wrench & Extensions ? JSoko Garage Talk: The Tool Depot™ 18 July 12th, 2009 10:01 PM
torque , useing , wrench
