Quantcast 1999 ford f-150 sas - Page 3 - Ford Truck Club Forum
  #21
Old May 24th, 2010, 01:14 PM
BigTrouble's Avatar
BigTrouble BigTrouble is offline
I found out on fords web site that the f150 have the 8.8 and 9.75 the f250 ld have the 10.25 and the f250/f350 super duty has the 10.50 and the f350/f450 Super Duty have the Dana 80 and the f550 has the Dana 135 rear axle.
  #22
Old May 24th, 2010, 01:39 PM
erm, pre 99 f250/350 had the 10.25
Not exactly sure about the f250 LD having a 10.25...
  #23
Old May 24th, 2010, 02:33 PM
DIXIE FIX's Avatar
Images: 504
Is your truck a f250LD or a f150 if its badged as an f150 the it has an 8.8 or 9.75. If it has the 5.4l v8 then you have the 9.75 all 5.4's came with the 9.75.
The 10.25 is no longer being used in the f250 or 350 it was replaced with the 10.5. Like said earlier the bolt patterns between the two are different.
But just a heads up the project will take longer than a weekend from start to finished. I've got 25.5 hours or grinding into mine. That's just to get started. Now if your saying a weekend after you get all the parts the there's a possibility that you can have it on its own weight but you will still need to have driveshafts made, brake lines made.
  #24
Old May 24th, 2010, 02:56 PM
AGH!!! brake lines. Damnit Cecil I spaced!
  #25
Old May 27th, 2010, 04:40 AM
BigTrouble's Avatar
yea I need to know stuff like that but I was going to use the stock super duty suspension on my truck and would like to know if yall think that the front drop down cross member would be a problem
  #26
Old May 27th, 2010, 01:25 PM
It will be, depending on your choice of lift height. I've seen it said many times now, 8" is bare minimum recommended lift to clear that front crossmember.
So 8+ your safe. less, well, then you'll be working even more.
  #27
Old May 31st, 2011, 04:47 AM
sallyliao's Avatar
sallyliao sallyliao is offline
DIXIE, OLD BLUE, KLITCH and/or WEBBY can probably help you the best there BT.
Ford Truck Club Website
4x4x4 , ASwaff400 , DIXIE FIX , jason77 , JSoko , Kickassguy , nine5flareside , sallyliao , Sc4x4truck , volvering , whitesleeper , willchase_19 , xxpaintballxx
1999 F150 302 swap DIXIE FIX 1997-2003 Ford F150
16 February 12th, 2011 10:29 PM
Ford and Toby Keith are giving away a 2011 Ford Super Duty Bates88 Garage Talk: General Tech Talk 0 June 30th, 2010 05:05 PM
1999 Ford Explorer Sport 2dr For SALE RedHot150 Vehicles For Sale
4 March 4th, 2010 03:39 PM
1999 F350 Super Duty 7.3 With Turbo Issue mustang512 1999-2007 Ford F250 | F350
17 February 18th, 2010 09:09 PM
1999 F150 Project: BEAST DIXIE FIX Garage Talk: Brakes & Suspension 66 November 26th, 2009 11:49 AM
1999 , f150 , ford , sas
