Quantcast Newbie SAS help - 97 f150 - Ford Truck Club Forum
Old March 2nd, 2011, 01:50 PM
coca1's Avatar
coca1 coca1 is offline
Images: 1
Default Newbie SAS help - 97 f150
Hey guys, been researching for what seems like forever on the solid axle swap. I have come a long way on understanding what needs to be done, and I'm fairly confident I can pull it off with enough work. But I am still a little lost on some details, and from my research it looked like everyone was a little lost.
Who can help me? I have a 1997 Ford F150 xl 4x4 4.6. Looking to beef it up, and give it some character...but I don't have a ton of money to throw around. Looking for the cheapest way to sas, without cheaping out too much. I am looking to put in Dana 60's (was told the d44 wouldn't be enough with my truck and 37" tires, is this correct?), and from what I can see, I would want Kingpins over ball joints. I am short on cash flow, so what are the advantages there, and are they worth it?
Just because I don't know 'exactly' what I'm doing, I would rather sas it with leafs and not coils, just in case. So, with intending to go leafs, what kind of axles should I be looking for? What year, from what truck, balljoint, kingpin, high pinion, just some info to clear what seems like lots of confusion about doing the sas.
I have found a great deal on Dana 60's front and rear from a 2006 f350. Will these work? Would they make sasing it harder?
Any and all information is appreciated, and I hope this thread can help more people than just me!
Old March 2nd, 2011, 02:44 PM
The king pin axles may be cheaper overall, stronger, "easier" to rebuild... From my understanding they're mostly pre 99 1 ton trucks, mostly.
2006 axles will be balljoint front axle, plus will be a radius arm / coil suspension axle. Also have unit bearings, which some people just cant bring themselves to want to deal with. With 37's, the unit bearings will be fine, its the guys running 40+ tires and have a lot of weight on them that have problems.
You could build a 44 to take on 37's... But you could start off with a 1-ton that will do it stock, sheer girth.
For leaf sprung, I can tell you the new balljoint style, 99-04. The older stuff I'm unfamiliar with complete configurations.
Old March 2nd, 2011, 02:59 PM
coca1's Avatar
Images: 1
Your thread is the one I've been following, glad you came and helped! To be honest, after seeing you do it step by step, I'd rather follow everything you did. Keeps things easy for me, haha.
You did yours with balljoint, but it sounds like I'd rather kingpin. Is there any other differences in the axles that would change the process of sas'ing it? Or is it just the bearings it uses?
If it's not a big deal, would you mind helping me out and messaging (or putting here, so it can help others) all the parts you used for your swap? Axles (front, rear, years, etc), shackles, bolts, driveshaft, just alittle sum of what you've done, so I don't have to go through your 15 page thread for the thousandth time, haha. A total price of parts would be much appreciated aswell, might give me a better idea of if I can really afford this now of not.
Old March 2nd, 2011, 03:07 PM
Thumbs up
because I will learn something
Old March 2nd, 2011, 03:08 PM
Real quick estimate of total cost without regearing the axles, just to get them under the truck, and in good condition.
$4500-5000
Keep in mind, this covered the cost of a kit from farmboy fab, that had premade parts to speed me along.
Spring perch width will be another major factor in the front axle choice. Though I dont think theres a whole lot of variance with the D60 fronts.
Many different lengths of grade 8 1/2" bolts
I used 2002 front/rear axles from a superduty
Old March 10th, 2011, 08:29 PM
4x4x4's Avatar
4x4x4 4x4x4 is offline
The kingpin axles have a narrower spring width than the 99+ ball joint axle which in my opinion is better since youre leafs will line up better with the frame so you wont need such an offset in your shackles. depending on the amount of lift you are going to have you can also bolt a high steer arm directly to the kingpin knuckle where as a balljoint axle will require the knuckle to be machined and an arm made to fit.
for mine I think im right around the 4000cdn range without wheels and tires. but I got my axles regeared with all new bearings seals etc for 1200 and made all the brakets hangers etc myself
Old March 12th, 2011, 10:56 AM
What is your budget besides cheap! Give us an idea of a number you are looking to play with...
Old March 18th, 2011, 05:56 AM
jason77's Avatar
jason77 jason77 is offline
do u wheel this truck or just drive it. i wheel my sploder on a 44 5.13s full detroit and chromoly shafts with 37" boogers on beadloc wheels with some air in them. have broke 1 shaft in 4 years. if ur just driving it and it isnt locked a 44 will be ok. ur going to pay more for a kingpin 60 and once again if ur not wheelin it that is more axle than u need and more money. i know people who wheel ball joint 60s no problems. so if ur not wheeling and locking it ur cheaper to go 44 and be ok. also the older axles if u have abs u will loose it. price wise coil buckets are cheap radius arm mounts are cheap. u can pic up coils where people have upgraded to coilovers or just went to taller ones. u can find them all day fairly cheep. leaf springs are gettting expensive.
Old March 18th, 2011, 06:01 AM
jason77's Avatar
another thing i forgot is if u go with a superduty axle u have to make sure it is a sixty. they put 50s in alot of them and i seen a few guys buy them thinking they are getting 6s then be mad when they find out.
Old March 18th, 2011, 02:05 PM
Pinion nut 1-5/16" = D60 in the balljoint era 99-2003 ~
(View-All Members who have read this thread : 22
4x4x4 , Agjake11 , alaskatabby , ASwaff400 , coca1 , DIXIE FIX , DoubleDee , faulkenberrycameron , Fordtruck1992 , herbz , imhsar , jason77 , JSoko , Kickassguy , Klitch , lilkix , nine5flareside , Russo2 , Sc4x4truck , tylerbotts , whitesleeper , xxpaintballxx
Newbie From GA Scott B. New Member Introductions 14 March 3rd, 2011 10:09 PM
Ford Newbie UpNort New Member Introductions 8 November 1st, 2010 08:36 PM
Newbie Cajun New Member Introductions 7 July 18th, 2010 09:48 AM
newbie TWIN SKULLS New Member Introductions 18 December 7th, 2009 08:38 AM
newbie in Delaware Pony Hauler New Member Introductions 17 July 18th, 2009 02:36 PM
f150 , newbie , sas
