January 3rd, 2010, 12:46 AM
6" lift plus level 2wd
I know people with 04-08 lifted trucks do this but i wasnt sure on the 97-03 trucks if this can be done.
ive been looking at the 6" lift kits with the drop down cross members longer spindles and longer coil springs. what im wondering is if i can use my 1.5' daystar coil spacer along with the kit and still keep a good set up.
specifically ive been looking at the rcd kits but they seem to only come with a 2" rear block for some reason so id probably have to go bigger in the back anyway. also this would be a way to save money and get to running 35"s. the kit says that 35" will fit with the kit with specific 16" wheels and certain bs with minor trimming. so this begs the question on if the spacer will fit with the kit then my thinking is this would negate the minor trimming required.
Thanks
04 F250 Lariat FX4 6.0L PSD - EGR Delete/Straight Piped - SCT w/ Gearhead Tunes - Edge CTS w/ EGT
04 Chebbie Tahoe LT - Stock w/ Nav and Bose - Pink TTS Sticker
January 3rd, 2010, 10:48 AM
Your UCA angles could be hurting a bit. ChrisT's truck doesn't look completely level, I would ask him since he already has the lift.
2004 F-150 Heritage 4.6
218.7 RWHP, 3980 lbs, 0-60 7.72 seconds :)
January 4th, 2010, 02:29 AM
well hes running a 6" block with the traction bars which im not gonna do.
i decided im gonna install the lift the way it was intended first to see what im gonna have to do for the rear then install the spacer. im pretty sure itll work out fine.
January 4th, 2010, 09:51 AM
Liked 14 Times in 14 Posts
Lifts and spacers arent a good combo! This has been discussed MANY times before. Are you wanting the Baja look? If so.....dont use the rear blocks supplied with the lift kit and get 1" shorter blocks made. DONT use a Daystar spacer on top of the lift kit itself!
Black Sheep of FTC
January 4th, 2010, 10:43 AM
January 4th, 2010, 12:17 PM
im gonna have the baja look either way i go since the kit only came with a 2" block. not something im going for.
im gonna go ahead today and tomorrow and install it as it came then see how everything is sitting and then go from there.
January 4th, 2010, 09:55 PM
Thats what I told B2Rad and he told me I was Effing nuts basically. Im not crazy hes just retarded to stack stuff like that.
January 5th, 2010, 12:14 AM
^^ not even worth trying to re-explain myself.
January 5th, 2010, 12:26 AM
I love seeing double and triple stacked rear blocks.....
Monthly Recognition Moderator
Check out my videos HERE
January 5th, 2010, 12:34 AM
thats pro comp. I wouldnt think stacking two would hurt though. Just as long as you arent talking big blocks
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
