'06 5.4 running rough TECHRON to the rescue - Ford Truck Club Forum
Old September 28th, 2017, 07:24 AM
Images: 616
Liked 169 Times in 151 Posts
Thumbs up '06 5.4 running rough TECHRON to the rescue
'06 5.4 XLT 4x4
78,000 miles
I have been driving around my area in the country, where my speed never gets much above 45mph and RPM's stay under 1800
I noticed that when i pulled a load like going up the mountain I get a slight miss. This miss was worst when i opened it up, it started to cough and stumble which finally got better as the RPM's reached 4000, but I still had the miss at low RPM's with a load
Well I remember that glc had recommended using TECHRON prior to plug change
I don't have a Chevron station in my area, just non branded mom & pop stations
I got 2 bottles of TECHRON, enough for 40 gallons of gas, which is about 600 miles of driving
I have got about 500 miles of driving and the problem has disappeared
I'm thinking I had loaded the plugs up with all the slow driving and that's what caused the miss
I may be in need of a plug change, something that I dread; I'm hoping I can get at least 100,000 miles out of the stock plugs
THANKS glc for your TECHRON advice
the air filter stays clean, and the oil is changed regular
any thoughts other than plugs causing this ???
Old September 28th, 2017, 10:31 AM
Liked 42 Times in 39 Posts
It's plugs. Ford changed the recommendation from 100k to 60k. Change them before the worn plugs cause the coils to start going bad.
Old September 28th, 2017, 12:49 PM
Images: 616
kinda what i thought but didn't want to hear that
this is not a job I would do
called 2 Ford dealers for pricing
no hidden charges if a plug breaks
Dealer A. $360 + $12ea if boot needs replacing
Dealer B. $530
Old September 28th, 2017, 03:17 PM
Images: 22
Dealer B must be going to change coil packs whether they need it or not.
Old September 28th, 2017, 07:58 PM
I would replace the boots.
Why don't you try to do it yourself? The Lisle tool makes broken plug extractions reasonably easy.
Crack the plugs loose 1/8 of a turn, pour some carb cleaner into the wells, let it soak, then work them out, loosening and tightening them till they come out.
High temperature nickel antiseize on the barrels when you replace them, 25 ft/lb, dielectric grease in the boots.
https://www.amazon.com/Motorcraft-SP.../dp/B00YI1HTNI
https://www.amazon.com/Standard-Moto.../dp/B00HFLDMGG
https://www.amazon.com/Permatex-7712.../dp/B0002UENJ2
https://www.amazon.com/Permatex-2205.../dp/B000AL8VD2
https://www.amazon.com/SYNFLEX-HOSE-.../dp/B018GJ506K
https://www.amazon.com/Lisle-LIS6560.../dp/B00267PZUK
https://www.amazon.com/dp/B000NBVFN2..._t2_B00267PZUK
JSoko (September 30th, 2017)
Old September 29th, 2017, 07:55 AM
Images: 616
Thumbs up
over the years I have read the TSB, and numerous Threads on the plug removal
with that list; makes it a no brainer for the DIY guy
I understand the use of the Leslie tool
I think the hardest part will be on my back (bending over)
and getting the socket on the plug (things in the way)
any suggestions on what to move out of the way AND what not to move
also, dose it make a difference which carb cleaner to use
I read that the MotorCraft carb cleaner in the red & white can is the best as it turns the carbon on the barrels to goo
Thanks George for the list (gives me confidence)
I will order the parts and do it myself (both of the Dealers are over 35 miles one way in different directions)
I'm sure I will have questions as I dive into this
any thing you can add would be appreciated
Thanks again
EDIT To Add: I found this tool, apparently it is newer & better than the Leslie and will not let the porcelain break - any opinions
https://www.otctools.com/products/fo...-kit-triton-3v ~ price range from $65 - $150
here's the part #/info - Product #: OTC6918 - OTC 6918 Ford Spark Plug Remover Tool Kit - Triton 3V
Old September 29th, 2017, 10:19 AM
I haven't heard anything about the OTC removal tool. I suppose the Motorcraft carb cleaner would be better than some generic stuff, that's actually what the TSB says to use. From what I hear, you may have to lift the fuel rail.
It may be easier on your back if you stand on a stool when doing the job.
Whatever removal tool you get, make sure you can return it if you don't need it and don't open it.
https://www.amazon.com/Motorcraft-CA.../dp/B0011DU14A
Old October 4th, 2017, 10:12 PM
BigT67's Avatar
BigT67 BigT67 is offline
Images: 262
When did the recommendation change occur? I'm just wondering if the dealer may have changed the plugs before I bought my truck. It had 82k on it when I bought it in 2015.
Big T
Old October 5th, 2017, 10:32 AM
I don't know when they did that, but I do know that it was done because of the removal issues.
Old October 6th, 2017, 09:25 AM
Images: 616
Hey T
BigT67 , Bulldog74 , danangmobile097 , glc , globalet93 , harrison28 , indoet93 , JSoko , Richfromseaford , sbellinghausen , Sydney , VuongPKN1
Running Rough Fords4ever 1997-2003 Ford F150
6 June 23rd, 2016 08:59 PM
slugish/no power/rough idle/bad gas millage judd94 1973-1991 Ford F150
4 January 14th, 2016 10:00 PM
Rough Idle, No power, black smoke??? adoporto 1992-1996 Ford F150
17 January 13th, 2014 11:41 PM
Hard start rough running Russo2 1973-1991 Ford F150
27 December 21st, 2012 07:48 AM
16 August 26th, 2012 10:44 AM
rescue , rough , running , techron
