Quantcast Eliminate the air suspension? - Ford Truck Club Forum
Ford Truck Club Forum > FORD F-250 | F-350 SERIES | SUPER DUTY > 1999-2007 Ford F250 | F350
Old October 9th, 2018, 03:44 PM
swivel's Avatar
swivel swivel is offline
Default Eliminate the air suspension?
My '98 F250 has the air suspension factory option. I only use the truck once a month to go to the dump. One rear air bag is non functional, extruded out of the coil spring etc. But before it went bad, the system had leaks etc. Will it just be a normal F250 if I pull the compressor fuse and not use the air suspension?
Old October 9th, 2018, 07:09 PM
Liked 76 Times in 73 Posts
Are you talking about the F250 LD that looks just like a F150?
Old October 9th, 2018, 08:21 PM
swivel's Avatar
Extended cab, 3 door F250. Triton engine.
Old October 9th, 2018, 09:44 PM
No, the trucks without air suspension use leaf springs and shock absorbers on the rear. 2wd fronts are coil springs and shocks, 4wd fronts are torsion bars and shocks.
Old October 10th, 2018, 02:13 PM
You could probably grab a set of leaf springs from a pick-n-pull for pretty cheap. Monroe Gas Magnum shocks are pretty good and reasonably priced.
(View-All Members who have read this thread : 4
Adrien , glc , harrison28 , swivel
91 f-350 suspension d.j.k 1987-1991 Ford F250 | F350
5 May 18th, 2014 07:03 AM
Air Suspension - Can You Really Have it All? TheSmokingTire The Smoking Tire 0 October 16th, 2013 05:27 AM
Suspension help. Ridgerunner Garage Talk: Shop Class 101 4 May 7th, 2012 10:41 PM
CV and TB Suspension Ridgerunner 1973-1991 Ford F150
5 March 20th, 2012 08:17 PM
Eliminate power steering WORLDWITHIN@VERIZON.NET 1993-1997 Ford Ranger
41 January 9th, 2012 09:27 PM
air , eliminate , suspension
