Quantcast Carburetor question - Ford Truck Club Forum
Old April 2nd, 2019, 11:14 AM
Default Carburetor question
I'm still quite new to the carburetor game. Right now the 351 has a 4 barrel Holley 600 with a set of 72 jets in it. I bought a 2 barrel Motorcraft carb at a swap meet that currently has a set of 58 jets in it. I want to try the 2 barrel kinda for the fun of it for a couple weeks just see what it does fuel mileage wise. My question for someone with much more carb experience, with it being a 2 barrel, is the jetting going to be smaller?, or will it matter? Should I assume that with 72's in the Holley, I should run something similar in the Motorcraft? I changed jets in the Holley multiple times to insure that the 72's were where it needed to be. I'm interested in any opinion.
Old April 3rd, 2019, 10:57 AM
Liked 96 Times in 93 Posts
The 4 barrel has both primary and secondary jets. The secondary is either vacuum or mechanically operated. The 2 barrel has no secondary. I don't know if you can translate jet size between 2 and 4 barrels. With a 2 barrel, it's reasonably straightforward, just read the plugs.
This may help:
https://www.musclecardiy.com/perform...bration-guide/
Old April 3rd, 2019, 02:51 PM
I kinda assumed reading the plugs would be my best option, other then using vacuum gauges and O2 sensors. Reading the plugs is how I got the Holley tuned. Thanks for the link.
Old April 12th, 2019, 09:02 AM
Images: 622
Liked 182 Times in 164 Posts
from way long ago I remember
trying the same
result was the 4bbl did better on MPG than the 2bb if you keep your foot out of the secondary's
most 2bbl carbs have higher CFM than a 4's primary
I did a write up about the particulars, but i can't find it
harrison28 (April 12th, 2019)
Old April 12th, 2019, 09:13 AM
That's good to know. I just a rebuild kit for my QFT 750 with mechanical secondary. I think now that our weather is steady, I'll do some testing with all 3 of my carbs. Maybe do a full tank with each one and see what the differences are. Give me something to do.
Old April 12th, 2019, 09:19 AM
Images: 622
what I remember is the 2bbls were in the 500 CFM and above
4bbl was less than 500 CFM (primary)
but even though I did this in the mid 70's when gas prices were sky high at half a dollar per gallon
the 4bbl went back on
Old April 12th, 2019, 09:29 AM
Images: 622
what i did do without switching carbs ('72 Dodge Demon 340 4bbl Thermoquad) was disconnect the link for the secondarys and they would not open
i got much better gas mileage on the hwy traveling, but always wondered if gas was getting sucked in the back from vacuum and it could have been better
this car went a lot faster than it could stop and it did not do well in curves
Old April 12th, 2019, 11:18 AM
I bet it was a fun ride though. I hadn't thought about disconnecting the secondary linkage. I'll try that also. I get about 11+ with a 600 cfm and vacuum secondary. This is all really just for info and is gonna just be trial and error. The truck isn't an over the road hauler or everyday driver. Thanks for the tips.
Old April 25th, 2019, 10:46 AM
Update #1- Ran another tank through the Holley 600 with vacuum secondaries. Averaged just over 11 1/2 mpg. All in town 10-12 mile round trip driving. I never disconnected the secondary linkage since I knew I wouldn't get into them around my little town. Gonna put the 750 double pumper on it here in the next day or 2. More results coming soon.
Old May 1st, 2019, 08:08 AM
Images: 622
any up-date
« Slave Cylinder Spacing | There is no next thread »
ditruthanhmy , glc , harrison28 , JSoko , The Bone
what carburetor do i have? tmace 1948-1986 Ford F250 | F350
24 December 10th, 2012 04:26 PM
Carburetor Basics JSoko Garage Talk: Shop Class 101 0 October 28th, 2012 02:31 PM
2150 Carburetor Rebuild Link BigBlue79 Garage Talk: Shop Class 101 1 September 20th, 2011 04:43 PM
carburetor installiation, and issues tjdinmaine 1980-1986 Ford Bronco
13 July 12th, 2011 10:52 PM
Frozen carburetor BigT67 General Discussion
0 December 19th, 2009 11:15 PM
carburetor , question
