Quantcast bypassing a seized aip pump - Ford Truck Club Forum
Old November 4th, 2014, 06:06 PM
imastank's Avatar
imastank imastank is offline
Default bypassing a seized aip pump
my smog pump seized on my 1997 f250 5.8. I thought i could just bypass it with a 94.5 inch belt. It seems to go on tight enough but when the engine is running it will eventually throw the belt (even at idle). Has anyone got any suggestions? Going down to a slightly smaller belt doesn't seem to be an option as its enough of a struggle slipping the 94.5" on.
Old November 4th, 2014, 09:24 PM
Why don't you go to the junkyard and find a smog pump that's not seized?
If you have to, a reman is $81.79 at rockauto.com.
Old November 4th, 2014, 10:19 PM
imastank's Avatar
Default bypassing seized air pump
Bypassing it seems to be the easier and cheaper route. Rock Auto lists two pumps for this vehicle (both remans from Cardone Autoparts) with two different part numbers (although they look the same). They cross-reference ID numbers which I think are supposed to correspond to the number on the pump I need to replace but I can't find any numbers on mine. Didn't want to go through the cost and aggravation of returning the pump if I guessed wrong.
Old November 11th, 2014, 09:26 PM
imastank's Avatar
Smile Bypassing a seized smog pump
In case anyone else needs to bypass their smog pump on a 5.8L I was able to do it by replacing the stock belt with a 94.2 inch one. I used a NAPA belt (part number 25060942). If you don't have a NAPA store nearby you could also try a Goodyear belt #4060942, a Gates #K060942, a Dayco #5060942, or part #942K6 from vbelts4less.com.
cdv , E250notF , Gallothrix , glc , Hemifish , imastank , JSoko , mr wu , Russo2
Vac,pump oil leak Dave8N in Pa 1992-1997 Ford F250 | F350
1 August 16th, 2014 03:23 PM
Failed Oil Pump ? 351C Cowboy-Kris 1948-1983 Ford F100
25 March 4th, 2014 08:21 AM
smog air pump ? muddy1977 1973-1991 Ford F150
7 October 31st, 2013 05:02 PM
7 Best Pump Shotguns for Less Than $500 JSoko General Discussion
1 June 18th, 2013 09:00 PM
How To: Replace A.I.R (Smog) Pump 92-96 V8s bikertrash3531 Garage Talk: Shop Class 101 18 March 30th, 2013 07:22 PM
aip , bypassing , pump , seized
