Quantcast 1998 E-150 Conversion Van for towing - Page 2 - Ford Truck Club Forum
Ford Truck Club Forum > ALL OTHER FORD MODELS > Ford Vans
Old December 5th, 2017, 10:12 PM
No idea on that, but I'd highly recommend you turn overdrive off when you are towing. If it doesn't have a separate transmission fluid cooler, I'd install one. I understand that a cooler off a Super Duty works very well. I'd also use synthetic transmission fluid. At least the torque converter has a drain plug, so you can get almost all of the old fluid out by dropping the pan and pulling the plug.
Old December 5th, 2017, 11:30 PM
moshe1436's Avatar
moshe1436 moshe1436 is offline
I do turn the OD off and it does have a tranny oil cooler. I do plan to use synthetic ATF Any thoughts on what brand? Thanks for your reply!
Old December 6th, 2017, 11:33 AM
I would use Amsoil or Mobil 1.
https://www.amsoil.com/shop/by-produ...?code=ATFQT-EA
https://mobiloil.com/en/automatic-tr.../synthetic-atf
Old December 6th, 2017, 12:09 PM
moshe1436's Avatar
Thanks for the recommendation on synthetic oils for the AT!
Old December 6th, 2017, 12:24 PM
moshe1436's Avatar
I've been researching the various ways to install a transmission temp gauge on my '98 Ford E-150 van with a 5.4 L engine and an E40D transmission.
There are quite a few opinions on where to put the sending unit! Some are insistent that it should go in the test port on the tranny and others say it should go on the line from the tranny to the cooler. I can see each view point and understand why each is recommended!
One source said putting it in the test port will only give you the temperature of the transmission case and not the oil which is what should be monitored. Thus putting it in the "hot" line from the tranny is best.
Other opinions are to use the OBD2 connector to monitor the tranny temp. For me this is too expensive and complicated! I want a separate gauge I can look at when I traveling to see what the temps are any moment.
So considering all of this I'm sure I want to put it in either the test port or the line. But before I order anything I want to be sure what I get will fit my tranny and vehicle. Even looking at the product descriptions on line I don't see any "vehicle specific" choices. By this am I correct to assume all gauges and their included parts will fit any vehicle? Are all test ports the same size thread and diameter?
Gosh! This sounds awfully complicated for what I'm trying to find out! Can anyone help?? Many thanks in advance.
Mo
79GreenishF100 , glc , harrison28 , JSoko , moshe1436
towing {(heavy towing) whats the max} michaelsnodgrass18 1992-1996 Ford F150
13 May 4th, 2013 01:32 AM
1998 f150 will not start! Less than 70k!!! Help me! justinTriton 1997-2003 Ford F150
8 January 20th, 2013 09:33 PM
Hello everybody! 1998 F150xlt justinTriton New Member Introductions 5 July 15th, 2012 01:07 AM
1998 Expedition Codes NEED HELP! eddog1345 Ford Expedition 2 January 1st, 2012 10:59 AM
Ranger: 1998-99 recalls BigT67 1998-2000 Ford Ranger
0 July 5th, 2009 06:35 PM
1998 , conversion , e150 , towing , van
