Quantcast Hellwig Products Sway Bar Install 1995 F150 - Ford Truck Club Forum
Ford Truck Club Forum > GARAGE TALK > Garage Talk: Brakes & Suspension
Old July 29th, 2010, 08:34 PM
Default Hellwig Products Sway Bar Install 1995 F150
OK I finally got around to installing my sway bar... well had it installed! I took the pics for you all to see though! I will post a full install article in the article section as well.
Here are just a few pics from the install:
And the installer:
Old July 30th, 2010, 02:11 AM
looks good man!
Old July 30th, 2010, 07:43 AM
Let me tell you, what a difference so far. I have only driven local but I already like the fact that the truck doesnt bounce as much when I hit bumps. Today I will take it for a long trip to see exactly how it feels with the sway bar.
Old August 1st, 2010, 10:04 PM
OK did a 2 hour test run over the weekend...
I went down the NJ TRNPK, crossed the Staten Island EXPWY, and then into Brooklyn, NY and back. That trip has some of the bumpiest roads you will find and at high speeds in my truck, can really suck. At times when driving 60 - 70 mph in my truck, if I were to hit a bump in the road, it would throw the truck over a good amount. To be honest, a dangerous amount.
I always thought it was due to Fords poorly designed front end, the TTB front end. After installing the Hellwig products sway bar on my rear Ford 8.8 axle, I was shocked to say the least. The truck handled perfectly. Bumps were no match for this truck at high speeds anymore. I will do a write-up in greater detail, just wanted to give you all the inside scoop.
If you are ever in the market for a sway bar and I suggest you get one, especially in the rear if you can only afford one, you need to check out Hellwig products and their full line of sway bars. After the difference I felt, a sway bar should be one of the first mods you do, along with a cold air intake system, exhaust and tuner. It will be worth every penny when your truck handles like a sports car for under 250 dollars.
F150GT
New Release by Hellwig Products Bates88 2009-2014 Ford F150
0 March 18th, 2010 01:08 PM
Hellwig Products Sway Bars Bates88 Garage Talk: General Tech Talk 1 January 9th, 2010 03:08 PM
Win Free Hellwig Sway Bars! nine5flareside Garage Talk: General Tech Talk 5 January 6th, 2010 02:08 PM
1995 F150 5.0L E303 Cam and Roller Lifter Install chatterjj Garage Talk: Shop Class 101 4 November 24th, 2009 09:22 PM
Hellwig Sway Bar Installation MOTORZ TV MOTORZ TV 14 September 21st, 2009 06:45 PM
1995 , bar , f150 , g&s performance engines , hellwig , install , products , sway , swaybar , swaybars
