Quantcast Fuel Pump Relay - Ford Truck Club Forum
Old March 23rd, 2012, 10:44 PM
Ridgerunner's Avatar
Images: 60
Liked 4 Times in 4 Posts
Default Fuel Pump Relay
My 85 F150 5.0 drives great when cold or near operating temperature. After it gets hot my truck would surge,buck and didn't want to run. I knew it had to be something in the fuel system causing this. I changed the fuel filter,and did a complete tune up. Still had the problem.
I was told by a friend to check the fuel pump relay and he explained how to do diagnostics check on it before throwing money and parts at it.
1. Pull the relay to check for corrosion. I cleaned the relay since it had a lot of corrosion and plugged it back up.
2. I got my multi meter out to check how many volts it would pull with the key on. Anything less than 12 volts is bad. Mine showed 11 volts.
When a fuel pump relay gets over heated it will cause the symptoms I just described,there also other things I will need to check Monday to make sure the fuel regulator is up to snuff.
Old March 23rd, 2012, 11:38 PM
How much does a Relay cost?
Old March 23rd, 2012, 11:41 PM
Images: 60
$10.00 to $15.00 depending on what you need. The one I need is BWD for $15.00. The great part is being able to so a little work to make sure that is what needs to be replaced. I will be doing one for the fuel regulator,which is more involved but easy to do.
Old March 24th, 2012, 10:40 PM
on the cleaning of the relay contacts
I have learned from experience that, Yes this will make it work, but go ahead and replace the relay cause its going to go out again real soon
Old March 24th, 2012, 10:44 PM
Images: 60
Yes that is true.I will replace the Relay Monday,I only cleaned the contacts so I could see how many volts it was putting out. Which showed it wasn't up to par and needs to be replaced.
Old March 25th, 2012, 07:35 AM
keep in mind a relay is a relay; wether it has 3 connectors or 6 it can be made to work
I use a Ford horn relay in place of the starter relay on my Harleys its so much cheaper than the HD brand
and a lawn mower starter relay works fine in the Ford Tractor
so if you are ever in a pinch you can make something work, it may not have the same mountig hardware but it will work
Old March 26th, 2012, 06:21 PM
Images: 60
I replaced the fuel pump relay today and tested the reading with the engine running. My meter showed 13 volts.
ALEXB , Aloomac , ASwaff400 , BigBlue79 , Booba5185 , DoubleDee , joe250 , JSoko , Ridgerunner , Russo2
smog air pump ? muddy1977 1973-1991 Ford F150
7 October 31st, 2013 05:02 PM
high volume oil pump jmoore704 1973-1991 Ford F150
6 October 28th, 2011 11:02 PM
Anyone ever remove their smog pump? nine5flareside 1992-1996 Ford F150
5 October 8th, 2010 11:00 AM
4 July 8th, 2010 09:43 PM
Bought A New Water Pump nine5flareside 1992-1996 Ford F150
1 August 14th, 2009 09:55 PM
fuel , pump , relay
