Quantcast 460 engine swap - Ford Truck Club Forum
Old June 4th, 2012, 02:15 PM
farmall's Avatar
farmall farmall is offline
Default 460 engine swap
Any body ever done 302 to 460 engine swap. I have a 2 wheel drive 94 f150
I want to put 460 in. Any help would be appreciated.
Old June 4th, 2012, 02:41 PM
Nice swap! Is it a stock 460?
We have a few guys that have done some swaps. I'm sure they will reply soon!
Old June 4th, 2012, 07:35 PM
That is a pretty big job, truthfully. You'll need a new transmission, new drive shaft, new engine crossmember, a remote mount oil filter, and thats just off the top of my head. Are you wanting to stay fuel injected or swap over to carb? Automatic or 5 speed?
Old June 4th, 2012, 10:17 PM
farmall's Avatar
I am going carb style. Got a local yard with an e350 van
Old June 4th, 2012, 11:28 PM
Are you going to use the transmission out of the van? I'm not sure if the frames are the same size, which matters since you need the crossmembers and driveshaft.
Old June 4th, 2012, 11:44 PM
He'll need a remote transmission controller if he's using his stock tranny and a Lokar shifter cable to use kickdown IIRC.
Old June 5th, 2012, 06:26 AM
farmall's Avatar
I have put a small block in a 86 ranger with a c6 behind it. Right now I am working on putting a small block in a 81 mustang that will have a c4 behind it. In 88 SVT did some f150s with 460s in them .I saw those at a Ford swap meet in Michigan that year.
Old June 5th, 2012, 09:22 AM
The 460 is a big block engine, a 302 is a small block engine, the bell housing is different and will not bolt up.
Blue, there would be no kickdown cable if he was using and electronic transmission, and he would only need the controller if it were an electronic transmission. He'd need one or the other, not both. That's if he could use the transmission out of his 94, which he can't.
Atate5 , BigBlue79 , Booba5185 , brads93bronco , Brokemech , bubba15848 , farmall , harrison28 , Inside Man , Johns 4x4x4 , jonny99 , lanejesse85 , Matthew , MAV1976 , nine5flareside , Russo2 , stromburg
engine swap 460 Dream 1992-1997 Ford F250 | F350
6 March 1st, 2012 09:40 PM
300 I6 Engine swap BigBlue79 Garage Talk: Engine & Drivetrain 29 January 10th, 2012 11:42 PM
Edelbrock Crate Engine Swap Horsepower TV EdelbrockTV EdelbrockTV 0 December 15th, 2011 09:11 PM
5.0L Engine Swap vol.1 section 4 (rental trailer) BADSHOE BADSHOE Productions 0 March 19th, 2011 12:42 PM
460 , engine , swap
