Quantcast Clutch master cylinder - Ford Truck Club Forum
Old August 29th, 2013, 10:27 PM
brick13's Avatar
brick13 brick13 is offline
Default Clutch master cylinder
So I am changing my clutch master cylinder this weekend. Story is well the factory part that was on it is made of plastic and when I pushed the clutch pedal down the plastic push rod snapped. I bought a new one at AZ that is all metal. Now my question for you guys is, can anyone tell me the best/ easiest way to bleed the cylinder once ive installed? or does anyone have any good links to videos on this or anything? Thanks.
Old August 29th, 2013, 10:35 PM
here is a video for a ford ranger there are several on youtube http://youtu.be/Pd1KDCAhTLc
Old August 29th, 2013, 11:54 PM
brick13's Avatar
Ok, i have a 1995 f150 with the 5.0, is it gunna be the same process?
Old August 30th, 2013, 06:51 AM
The ranger manual trans is a M5ODR1 and yours is a M5ODR2. The process will be very similar.
Old August 30th, 2013, 10:57 PM
brick13's Avatar
So i got the master cylinder all changed out today, and i bled it just like that video in the link, and it worked out pretty good. The truck is driveable again, but the pedal feels a lil soft now. Im gunna try bleeding it again 2morrow and see if it works it out.
Old August 30th, 2013, 11:04 PM
good deal!
Old August 31st, 2013, 12:38 AM
Try back bleeding it. Get one of those little oil cans where you pump the handle. Put a hose over the spout and connect it to the bleeder screw, fill the can with brake fluid. Take the cap off the master cylinder, crack the bleeder screw loose and start pumping the can.
Old August 31st, 2013, 07:52 AM
thats the same way I do old Harley master cylinders, but I use a 60cc irrigation syringe
Old August 31st, 2013, 12:06 PM
brick13's Avatar
I will give it a try. Thanks.
bikertrash3531 , brick13 , elwray , F150GT , glc , jones03100 , JSoko , nflfreak43 , rikard , skatebowd , SlydinClyde , The Frankster , x1488x
'95 F250 4x4 slave cylinder issues... 1977 F-250 4x4 Custom 1992-1997 Ford F250 | F350
3 January 6th, 2013 11:14 AM
Cylinder Head Temps Bates88 2004-2008 Ford F150
0 August 10th, 2012 03:08 PM
How to Bleed the Clutch on a 1995 F-150 JSoko Garage Talk: Shop Class 101 0 May 3rd, 2012 07:44 PM
cylinder head temp sensor cecil281 1997-2003 Ford F150
2 October 17th, 2011 06:23 PM
Master cylinders Jamesimm Garage Talk: Brakes & Suspension 1 October 28th, 2010 06:10 AM
clutch , cylinder , master
