Quantcast 1977 F-150 VIN help! - Ford Truck Club Forum
Old August 8th, 2015, 12:21 AM
ktm126's Avatar
ktm126 ktm126 is offline
Images: 30
Default 1977 F-150 VIN help!
Hi I have a 1977 f150 4x4 and I was wondering if anyone could point me in the correct direction of a website that gives correct info on a 11 digit vin. hOr if someone here could Decode this for me it would be greatly appreciated. Or if their is a thread on here that I missed on this topic
VIN:F14HLX92751
Thanks,
Will
ID:	1125   Click image for larger version
Old August 8th, 2015, 09:09 AM
1. First three characters - F10 - Truck Series Code
F10 - F100 2 Wheel Drive
F11 - F100 4 Wheel Drive
F14 - F150 4 Wheel Drive
F15 - F150 2 Wheel Drive
F25 - F250 2 Wheel Drive
F26 - F250 4 Wheel Drive
2. Fourth character - A - Engine Code
A - 6 cyl - 240cid - 1BBL carb - 1973-74
B - 6 cyl - 300 cid - 1BBL carb - 1973-80
G - V8 - 302cid - 2BBL carb - 1973-80
H - V8 - 351cid - 2BBL carb - 1973-80
Y - V8 - 360cid - 2BBL carb - 1973-76
H - V8 - 390cid - 2BBL carb - 1973-76
M - V8 - 390cid - 4BBL carb - 1974-78
S - V8 - 400cid - 2BBL carb - 1977-80
J - V8 - 460cid - 4BBL carb - 1973-80
3. Fifth character - U - Assembly Plant Code
B - Oakville, Ontario, Canada
C - Ontario, Canada
E - Mahhaw, NJ
H - Lorain, OH
I - Highland Park, MI
K - Kansas City, MO
L - Michigan Truck
N - Norfold, VA
P - Twin Cities, MN
R - San Jose, CA
S - Allen Park, MI
U - Louisville, KY
V - Kentucky Truck
4. Remaining six characters - 100001 - This is a numeric code for the vehicle build sequence. In some cases there could be two letters and four numbers.
Old August 8th, 2015, 09:13 AM
newer models
Note: This VIN decoder is a bit out-dated so if it doesn't work for your vehicle, just use the Ford one.
Here is a little help on decoding that VIN.
VIN stands for Vehicle Identification Number. It is a 17-digit sequence of letters and numbers that is basically your vehicle's serial number. It is unique to your vehicle. No other vehicle in the world will have the same VIN. It can be found at the front of the dash on a metal plate, visible through the windshield on the driver's side. As well, it is also found on the door sticker on the driver's side door jamb.
Note: Every attempt has been made to include complete, accurate information. This page contains Ford truck related VIN information.
Diagram of VIN Tag
1. World Vehicle Manufacturer
1FM — Ford Motor Company, USA, multi-purpose vehicle
1FT — Ford Motor Company, USA, truck, completed vehicle
1FD — Ford Motor Company, USA, incomplete vehicle
1FC — Ford Motor Company, USA, basic (stripped) chassis
1FB — Ford Motor Company, USA, bus
1FF — Ford Motor Company, USA, motor vehicle equipment without engine/powertrain (Glider)
1MH — Mercury, USA, incomplete vehicle
2FM — Ford Motor Company, Canada, multi-purpose vehicle
2FT — Ford Motor Company, Canada, truck, completed vehicle
2FD — Ford Motor Company, Canada, incomplete vehicle
2FC — Ford Motor Company, Canada, basic (stripped) chassis
2FB — Ford Motor Company, Canada, bus
2FF — Ford Motor Company, Canada, motor vehicle equipment without engine/powertrain (Glider)
2MH — Mercury, Canada, incomplete vehicle
3FB — Ford Motor Company, Mexico, bus
3FC — Ford Motor Company, Mexico, basic (stripped) chassis
3FE — Ford Motor Company, Mexico, incomplete vehicle
3FM — Ford Motor Company, Mexico, multi-purpose vehicle
3FT — Ford Motor Company, Mexico, truck, completed vehicle
4M2 — Mercury, USA, multi-purpose vehicle
4M3 — Mercury, USA, incomplete vehicle
4M4 — Mercury, USA, truck, completed vehicle
2. Brake Type and Gross Vehicle Weight Rating (GVWR) (all vehicles with hydraulic brakes)
A — 0-3000 Pounds
B — 3,001-4,000 Pounds
C — 4,001-5,000 Pounds
D — 5,001-6,000 Pounds
E — 6,001-7,000 Pounds (may also be "R")
F — 7,001-8,000 Pounds
G — 8,001-8,500 Pounds
H — 8,501-9,000 Pounds
J — 9,001-10,000 Pounds
K — 10,001-14,000 Pounds
L — 14,001-16,000 Pounds
M — 16,001-19,500 Pounds
3. Vehicle Line, Series, Body Type
E11 — Econoline Club Wagon
E31 — Econoline Club Wagon (Heavy Duty)
S31 — Econoline Club Wagon (Super Club Wagon)
E14 — Econoline E-150 (Cargo Van)
E24 — Econoline E-250 (Cargo Van)
E27 — Econoline E-250 (Commercial Cutaway)
E29 — Econoline E-250 (Commercial Basic)
E30 — Econoline E-350 (RV Cutaway)
E34 — Econoline E-350 (Cargo Van)
E37 — Econoline E-350 (Commercial Cutaway)
E39 — Econoline E-350 (Commercial Basic)
S24 — Econoline E-250 (Super Van)
S34 — Econoline E-350 (Super Van)
E40 — E-Super Duty (RV Cutaway)
E47 — E-Super Duty (Commercial Cutaway)
F07 — F-150 Flareside, 4x2
X07 — F-150 (SuperCab) Flareside, 4x2
F08 — F-150 Flareside, 4x4
X08 — F-150 (SuperCab) Flareside, 4x4
F17 — F-150 Styleside, 4x2
X17 — F-150 (SuperCab) Styleside, 4x2
F18 — F-150 Styleside, 4x4
X18 — F-150 (SuperCab) Styleside, 4x4
F27 — F-250 Styleside, 4x2
X27 — F-250 (SuperCab) Styleside, 4x2
F28 — F-250 Styleside, 4x4
X28 — F-250 (SuperCab) Styleside, 4x4
U22 — Explorer (2-door), 4x2
U32 — Explorer (4-door), 4x2
U24 — Explorer (2-door), 4x4
U34 — Explorer (4-door), 4x4
U35 — Explorer (4-door), AWD
U52 — Mountaineer (4-door) 4x2
U54 — Mountaineer (4-door) 4x4
U55 — Mountaineer (4-door) AWD
R10 — Ranger 4x2
R11 — Ranger 4x4
R14 — Ranger 4x2 (2-door SuperCab)
R15 — Ranger 4x4 (2-door SuperCab)
R18 — Ranger 4x2 (4-door SuperCab)
R19 — Ranger 4x4 (4-door SuperCab)
4. Engine Type
A — 2.3L EFI, four cylinder (Ranger 1997 and older)
6 — 4.6L EFI-SOHC (Windsor), eight cylinder (Econoline, F-150, F-250)
W — 4.6L EFI-SOHC, eight cylinder (F-150, F-250)
L — 5.4L EFI-SOHC, eight cylinder (Econoline, F-150, F-250)
S — 6.8L EFI-SOHC, ten cylinder (Econoline)
F — 7.3L Turbo-Diesel, eight cylinder (Econoline)
2 — 4.2L EFI-OHV, six cylinder (Econoline, F-150, F-250)
Z — 5.4L SOHC, gaseous fuel prep, eight cylinder (Econoline, F-150, F-250)
M — 5.4L SOHC natural gas, eight cylinder (Econoline, F-150, F-250)
X — 4.0L EFI-OHV, six cylinder (Explorer, Ranger)
E — 4.0L EFI-SOHC, six cylinder (Explorer, Mountaineer)
P — 5.0L EFI, eight cylinder (Explorer/Mountaineer)
B — 2.5L OHV-DI diesel, four cylinder (Ranger)
C — 2.5L EFI-SOHC, four cylinder (Ranger)
U — 3.0L, six cylinder (Ranger)
5. Check Digit
This is a generated number.
6. Model Year
V — 1997
W — 1998
X — 1999
Y — 2000
1 — 2001
2 — 2002
7. Assembly Plant
L — Michigan Truck (Wayne, Michigan)
S — Allen Park (Allen Park, Michigan)
H — Lorain (Lorain, Ohio)
C — Ontario Truck (Oakville, Ontario)
E — Kentucky Truck (Jefferson County, Kentucky)
K — Kansas City (Claycomo, Missouri)
N — Norfolk (Norfolk, Virginia)
U — Louisville (Louisville, Kentucky)
Z — St. Louis (Hazlewood, Missouri)
P — Twin Cities (St. Paul, Minnesota)
T — Edison (Edison, New Jersey)
8. Production Sequence Number - this is an alphanumeric code for the vehicle build sequence. This is also the vehicle serial and warranty number.
A00001-E99999 — Ford Division
J00001-L99999 — Lincoln-Mercury Division
Old August 8th, 2015, 09:15 AM
rear end info can be found on the metal tag attached to one of the bolts
IF it's still there
Old August 8th, 2015, 09:17 AM
Here is an example of the vehicle sticker you will find in the driver's side door jamb:
Sticker on driver's side door jamb
Here is what each of the items are (corresponding numbers):
Exterior Paint Code
Region Code
Domestic SpeciaOrder Code
Wheelbase Code
Brake Code
Interior Trim Code
Tape/Paint Pinstripe Code
Radio Code
Axle Code
Transmission Code
Spring Code
I won't decode each of these items, but I wildecode the popular ones. If you want more help in decoding your tag further, just post a message in our forums.
Now for the decoding:
Axle Codes (LS=Limited Slip / Traction Lok):
F-150:
19 – 3.55 Non-LS
18 – 3.08 Non-LS
H9 – 3.55 LS
B6 – 3.73 LS
F-250:
27 – 3.31 Non-LS
26 – 3.73 Non-LS
Ranger:
84 – 3.45 Non-LS
86 – 3.73 Non-LS
87 – 4.10 Non-LS
89 – 4.56 Non-LS
F6 – 3.73 LS
F7 – 4.10 LS
92 – 3.08 Non-LS
R5 – 3.55 LS
91 – 3.27 Non-LS
96 – 3.73 Non-LS
R6 – 3.73 LS
Transmission Codes:
U – Automatic 4R70W (F-150, F-250)
E – Automatic E4OD (F-150, F-250)
M – 5 speed manuaoverdrive (F-150, F-250, Ranger)
D – Automatic 5 speed (Ranger)
T – Automatic 4 speed (Ranger)
Spring Codes
The following lists available spring codes.
Front Springs
1 — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250, Explorer/Mountaineer)
2 — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250, Explorer/Mountaineer)
3 — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250)
4 — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250)
G — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250)
8 — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250)
9 — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250)
Z — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250)
T — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250)
U — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250)
6 — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250)
C — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250)
E — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250)
F — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250)
B — 5B326 (RH), 5B327 (LH) torsion bar (Explorer/Mountaineer)
D — 5B326 (RH), 5B327 (LH) torsion bar (Explorer/Mountaineer)
E — 5B326 (RH), 5B327 (LH) torsion bar (Explorer/Mountaineer)
F — 5B326 (RH), 5B327 (LH) torsion bar (Explorer/Mountaineer)
G — 5B326 (RH), 5B327 (LH) torsion bar (Explorer/Mountaineer)
H — 5B326 (RH), 5B327 (LH) torsion bar (Explorer/Mountaineer)
J — 5B326 (RH), 5B327 (LH) torsion bar (Explorer/Mountaineer)
L — 5B326 (RH), 5B327 (LH) torsion bar (Explorer/Mountaineer)
P — automatic ride contro(Explorer/Mountaineer)
A — 5310 spring (Econoline, F-150, F-250, Ranger)
B — 5310 spring (Econoline, F-150, F-250)
C — 5310 spring (Econoline, Ranger)
D — 5310 spring (Econoline, Ranger)
E — 5310 spring (Econoline, Ranger)
F — 5310 spring (Econoline, Ranger)
G — 5310 spring (Econoline, Ranger)
H — 5310 spring (Econoline, Ranger)
J — 5310 spring (Econoline, F-150, F-250)
K — 5310 spring (Econoline, F-150, F-250, Ranger)
L — 5310 spring (Econoline, F-150, F-250)
M — 5310 spring (Econoline, F-150, F-250, Ranger)
N — 5310 spring (Econoline, F-150, F-250, Ranger)
P — 5310 spring (Econoline, F-150, F-250)
R — 5310 spring (Econoline, F-150, F-250)
S — 5310 spring (Econoline, F-150, F-250)
T — 5310 spring (Econoline, Ranger)
U — 5310 spring (Econoline)
V — 5310 spring (Econoline)
W — 5310 spring (Ranger)
Z — 5310 spring (Econoline)
Rear Springs
6 — 5560 spring (Econoline)
7 — 5560 spring (Econoline)
C — 5560 spring (Econoline, F-150, Ranger)
E — 5560 spring (Ranger)
N — 5560 spring (Econoline, F-150)
P — 5560 spring (Econoline, F-150)
R — 5560 spring (Econoline, Ranger)
S — 5560 spring (Econoline, Ranger)
T — 5560 spring (Ranger)
X — 5560 spring (Ranger)
G — 5560 spring (Econoline, F-150)
K — 5560 spring (Econoline, F-150, Ranger)
A — 5560 spring (F-150)
B — 5560 spring (F-150)
D — 5560 spring (F-150)
F — 5560 spring (F-150, Explorer/Mountaineer)
H — 5560 spring (F-150, Explorer/Mountaineer)
J — 5560 spring (F-150)
L — 5560 spring (F-150, Explorer/Mountaineer)
1 — 5560 spring (F-250)
2 — 5560 spring (F-250)
3 — 5560 spring (F-250, Ranger)
4 — 5560 spring (F-250)
X — 5580 spring, load-leveling suspension (F-250)
Y — 5580 spring, load-leveling suspension (F-250)
Interior Trim Codes
The following lists the interior trim and interior color codes:
Interior Trim
A — Hampton vinybucket seats — Econoline
E — Camden cloth captain chairs — Econoline
C — Stockton vinybucket seats — Econoline
F — Kirk cloth captain chairs — Econoline
A — vinyfulbench seat (split back), vinyfulbench (Mexico) — F-150, F-250
C — polyknit fulbench seat (split back), polyknit fulbench (Mexico) — F-150, F-250
F — cloth captains chairs with console — F-150, F-250
H — leather captains chairs with console — F-150, F-250
M — cloth 40/60 bench seat — F-150, F-250
E — leather 40/60 bench seat — F-150, F-250
A — vinybucket seats (Explorer)
J — cloth premium bucket seats (Explorer/Mountaineer)
Z — cloth sport bucket seats (Explorer/Mountaineer)
G — cloth sport bucket seats — less power (Explorer)
F — leather sport bucket seats (Explorer/Mountaineer)
M — cloth split bench seat (Explorer)
1 — limited leather sport bucket seats (Explorer)
H — simulated split vinybench seat (Ranger)
E — Cirrus cloth 60/40 split bench seat (Ranger)
G — Triad luxury sport bucket seats (Ranger)
Interior Color Codes
X — Medium Prairie Tan (F-150, F-250, Explorer/Mountaineer, Ranger)
2 — Medium Graphite (Econoline, F-150, F-250, Explorer/Mountaineer, Ranger)
S — Willow Green (F-150, F-250, Explorer/Mountaineer, Ranger)
D — Denim Blue (Econoline)
P — Mocha (Econoline)
N — Cordovan (F-150, F-250)
E — Dark Denim Blue (Explorer/Mountaineer, Ranger)
Tape Stripe Codes
B — Silver/Red — Econoline (Chateau)
C — Light Teal/Red — Econoline (Chateau)
D — Medium Silver/Red — Econoline (Chateau)
H — Silver Metallic/Heliotrope (F-150, F-250) 4x2
2 — Ebony/Amethyst (F-150, F-250) 4x2
T — Silver Metallic/Medium Titanium (F-150, F-250) 4x4
5 — Ebony/Graphite Sparkle (F-150, F-250) 4x4
R — Silver/Dark Toreador — upper, Dark Toreador/Silver — lower (F-150, F-250 Lariat)
8 — Dark Blue/CoraPeach — upper and lower (F-150, F-250 Lariat)
9 — Bright Green/Pacific Green — upper, Pacific Green/Bright Green — lower (F-150, F-250 Lariat)
S — Silver/Ebony/Silver — upper, Ebony/Silver/Ebony — lower (F-150, F-250 Lariat)
C — Light Prairie Tan/Heliotrope (F-150, F-250) 4x2
F — Light Prairie Tan/Medium Titanium (F-150, F-250) 4x4
V — Violet Metallic kit (Explorer XLT)
W — Light Willow kit (Explorer XLT)
R — Medium Santa Fe kit (Explorer XLT)
P — Platinum kit (Explorer XLT)
G — Anniversary Gold (Mountaineer)
P — Oxford White/Platinum (Mountaineer)
R — Toreador Red/Platinum (Mountaineer)
W — Medium Wedgewood/Platinum (Mountaineer)
Y — Pacific Green/Platinum (Mountaineer)
U — Ebony/Platinum (Mountaineer)
0 — Light PearGold Metallic (Explorer Limited)
1 — CharcoaGreen (Explorer Limited)
2 — Desert Violet (Explorer Limited)
3 — Ebony (Explorer Limited)
P — Platinum (Ranger XLT "Off Road")
S — Silver (Ranger XLT "Off Road")
B — Blue/Dark Blue (Ranger XLT)
C — Copper/Gold (Ranger XLT)
G — Green/Gold (Ranger XLT)
T — Tea(Ranger Splash)
V — Violet (Ranger Splash)
4 — Silver/Medium Graphite (Ranger SE/LE)
5 — Beige/Brown (Ranger SE/LE)
8 — Santa Fe/Woodrose (Ranger SE/LE)
58ford32 , azfordguy , glc , harrison28 , JSoko , ktm126 , Shanevc
1977 F250 Gas 2WD HighBoii 1948-1986 Ford F250 | F350
7 July 24th, 2014 09:10 AM
1977 F 250 4x4 dlamothe New Member Introductions 3 February 4th, 2013 08:53 PM
1977 ford f250 highboy tenagray New Member Introductions 7 February 17th, 2012 09:14 AM
Need bug shield 1977 f150 missyvalley 1973-1991 Ford F150
6 October 3rd, 2011 12:11 AM
1977 F250 4X4 Low Boy IRT.250 New Member Introductions 5 September 8th, 2011 09:24 PM
1977 , f150 , vin
