Quantcast 1996 Bronco with rear window issues... - Ford Truck Club Forum
Ford Truck Club Forum > FORD BRONCO | BRONCO II > 1992-1996 Ford Bronco
Old August 21st, 2012, 11:30 AM
LOBO2's Avatar
LOBO2 LOBO2 is offline
Default 1996 Bronco with rear window issues...
I have a 1996 Bronco that has an issue with the rear window. It goes down ok, but going up has always been a problem. All the "mechanics" that worked on it have either replaced the motor, greased the lift arms, or both. Neither seem to help for any significant amount of time.
Any words of wisdom for a fix?
Old August 21st, 2012, 11:35 AM
Is it making noise when it tries to go up or not doing anything at all? It could be electrical, like a dirty or bad switch or something.
Old August 21st, 2012, 11:44 AM
Could be the connection in the tailgate for the Electric Motor. Sounds as if it's either corroded or dirty from years of dust and rain and such getting in the tailgate.
Old August 21st, 2012, 02:41 PM
also doing climbing and the angles as seen in your intro, can twist the body causeing things to get out of wack
this more than likely is not the problem, but something to remember next time you get sideways
Old August 22nd, 2012, 12:19 AM
LOBO2's Avatar
I forgot that the switch where the key goes in has been changed, as well as the motor.
Old August 23rd, 2012, 12:37 PM
taxreliever's Avatar
taxreliever
Guest
Posts: n/a
What exactly is it doing when it goes up? Does it move at all? Is it sluggish? And is it doing it with the key as well as the dash switch?
I had just gone through this, so it's incredibly fresh in my mind. I recently bought a 92 Bronco and rear window issues are as normal as a worn tire with broncos because of the tailgate.
If it's sluggish but still moving, I've been told that the motor should be ok, but you're saying you replaced it. The other thing that's common is power from the dash switch gets lost or grounded in it's travels and adding a relay switch helps give it more power and thus makes it go up and down faster.
Check weatherstripping.....you said it was all greased?
Good luck. Just one of those PITA normalities with Broncs.
BigBlue79 , BigRob , Booba5185 , DoubleDee , HiRoller , JSoko , Kmh3212 , Lifted_Bronco , LilaBar , LOBO2 , Lostin90s , southernhonkey , TheAmplified42
Free 1973-1979 F-Series Rear Sliding Window BigBlue79 Auto Parts For Sale
0 August 12th, 2012 09:08 PM
1996 ford whitesleeper Vehicles For Sale
5 April 26th, 2012 07:43 AM
How To: Greasing the rear Driveshaft Slip Joint in a 1980-1986 Bronco BigBlue79 Garage Talk: Shop Class 101 0 October 13th, 2011 02:49 AM
Traded in my 1996 Jordan 1997-2003 Ford F150
12 February 9th, 2011 04:09 AM
Wanting A 1979- 1996 bronco BigTrouble Auto Parts Wanted
7 June 17th, 2010 09:37 PM
1996 , bronco , issues , rear , window
