Quantcast Rear Window - Ford Truck Club Forum
Old May 30th, 2013, 02:22 PM
TwoSpeed's Avatar
TwoSpeed TwoSpeed is offline
Default Rear Window
Is it possible to swap out the one piece back glass out for a sliding rear window? I like those better plus I feel that with the triangle front windows it would look better together.
Old May 30th, 2013, 05:54 PM
Yes. It is possible.
Old May 30th, 2013, 06:26 PM
tylerbotts's Avatar
tylerbotts tylerbotts is offline
Location: outskirts of new orleans in a city called metairie
Images: 8
yep
MODS
-no cats w/dual 40 series flowmaster
-2in lift on 34s
-front brush bar
-bed roll/light bar with 4KC kights
-built 4.6 motor
Old May 30th, 2013, 08:28 PM
I've done it before using a string
check for some youtube directions
Old May 30th, 2013, 09:10 PM
yep I did on my 83
Old May 31st, 2013, 11:37 AM
TwoSpeed's Avatar
Ok so another question is where might be a good place to look for one? Also how do I tell what engine family my engine is? I know its probably not the BOSS but how do I tell wether its the small block windsor or the modular V8?
Old May 31st, 2013, 12:09 PM
if your '95 F150 has a V-8 you have either a 5.0 or 5.8 windsor
post your VIN # and we can tell you all about it
Old May 31st, 2013, 01:49 PM
The Upper intake Plenum will I.D the engine you have. In 92-96 the only available V8's were the 5.0L 302cid or the 5.8L 351cid in the F150, both of which are Windsor family engines. The Modular engines are a totally different animal compared to the Windsor. The Modulars are overhead cam vs the Windsors overhead valve pushrod design. Also the Modulars didn't show up until model year 1997 F150.
As far as a sliding rear window is concerned, you can hunt through local junkyards or order new from websites like:
http://www.lmctruck.com
http://www.npdlink.com
Old May 31st, 2013, 02:01 PM
TwoSpeed's Avatar
Default Vin
1ftef15n9snb64710
Old May 31st, 2013, 02:10 PM
TwoSpeed's Avatar
Where might I find a good rebuild kit? Should I do the bearings or just make sure I check them really well? I want to completely rebuild the engine and trans? For now I just want to keep it simple and stay stock and then as time and money permit build an engine and trans with some more power behind it.
bikertrash3531 (June 1st, 2013)
BigBlue79 , bikertrash3531 , Booba5185 , F150GT , glc , Hazzardousmat , jones03100 , JSoko , Kaotik , Lostin90s , MADV79 , skatebowd , The Frankster , TwoSpeed , tylerbotts , woodrock , yahnke
sliding window latch jones03100 1992-1996 Ford F150
14 March 20th, 2013 03:43 PM
1996 Bronco with rear window issues... LOBO2 1992-1996 Ford Bronco
5 August 23rd, 2012 12:37 PM
Free 1973-1979 F-Series Rear Sliding Window BigBlue79 Auto Parts For Sale
0 August 12th, 2012 09:08 PM
Window Trim MR_Pete Garage Talk: Paint & Detailing 11 April 12th, 2011 06:47 PM
rear , window
