Quantcast 1995 F150 - Need Help! - Page 3 - Ford Truck Club Forum
  #21
Old January 14th, 2012, 12:50 AM
http://oldfuelinjection.com/?p=27
  #22
Old January 14th, 2012, 01:05 AM
Okay so now what exactly do I do, same with IAC.
Cleaned one IAC and then went to a second JY one, and still have a random higher idle and a surging at steady throttle.
  #23
Old January 14th, 2012, 08:55 AM
Originally Posted by Booba5185 View Post
Great news! Glad to hear you got it fixed. I wanna see that motor in action, aside from the E303 cam, its the way I wanna go with mine...might be a 351 instead of a 302, but who knows.
The E303 cam in my opinion is not so good for everyday local driving... just look at it's RPM range... something I should have really thought about before installing.
Another thing... the f150 stock automatic transmissions - E4OD - and the E303 cam... not so good together. The torque converter needs to be changed for this cam to really work as best as it can on an auto trans.
If your car or truck is stick, this cam will be fine BUT the same issue still applies with the cams RPM range.
I haven't bothered to change mine yet.
I'm thinking about an entirely new trans to replace the E4OD but thats another subject for a future thread!
Knowing what I know now,
While I had the block out, I really should have went the 331 stroker route with some nice AFR heads and a mild cam. A nice torquey engine that could smoke the tires with no problem when the light turned green!
Just my opinion on things...
  #24
Old January 14th, 2012, 09:05 AM
Russo,
While your f150 is running, unplug your IAC harness. See if the idle changes... mine didn't at all so that was the extra kick I needed to just swap it out. Mind you, I had cleaned it pretty well only days before.
If the idle doesn't change, my suggestion is to buy a new IAC, forget JY parts for something like this. A new one is cheap enough and easy to swap as you know and will really put all doubts to rest as far as the IAC being the issue.
Two affordable options are:
Auto Zone
Advance Auto
I went with Advance Auto because it was a dollar cheaper and came with a new gasket. The Auto Zone one was a dollar more and no gasket... WTF!
Advance Auto
Regular Price: 41.99
20% Discount Code: P20
New Price: 33.59
10 Dollars Off Discount Code: RETMENOT123
New Price: 31.99
I used the second code, but if it's expired, go with the trusty P20 code!
So buy a new one, swap it out... good, cheap starting point.
I'm not sure but does your truck have a MAF sensor?
  #25
Old January 14th, 2012, 11:46 AM
No, it's speed density, uses a MAP sensor. Which I do believe is causing my "bucking" at steady throttle.
  #26
Old January 14th, 2012, 12:06 PM
well Nine5, its hard to pinpoint some problems on an EFI
Hallelujah, and there was Peace in the Land
PS: 331 & carb
  #27
Old January 14th, 2012, 12:18 PM
Anyone got a good way to check the map sensor?
did you do a search ??? this may help
http://www.fordtruckclub.net/forum/s...ead.php?t=5368
  #28
Old January 14th, 2012, 01:11 PM
Tits. Thanks J.
It's currently 5 degrees outside, I'll worry aboot it later.
  #29
Old January 14th, 2012, 01:33 PM
Tits. Thanks J.
yeah, that will give ya chaped lips
  #30
Old January 15th, 2012, 07:54 PM
Good going JS!
(View-All Members who have read this thread : 28
92Nite! , adoporto , ASwaff400 , BigTrouble , bikertrash3531 , Booba5185 , bronco40 , cools , darin , DoubleDee , fightlife1437 , HawaiianF150 , Herbie , JSoko , Lostin90s , mucklife13 , nightshade , nine5flareside , pete59edsel , rags2013 , Russo2 , sbellinghausen , skatebowd , Ted94 , TnFord , whitesleeper , woodrock , zmr2010
1995 F150 Lift, Looking for suggestions RyanH755 1992-1996 Ford F150
15 October 20th, 2011 05:51 PM
1995 f150 vids ASwaff400 1992-1996 Ford F150
1 September 20th, 2011 05:53 PM
1995 F150 Misfire nine5flareside 1992-1996 Ford F150
10 June 14th, 2011 08:07 AM
1995 F150 Video nine5flareside 1992-1996 Ford F150
2 December 13th, 2010 09:23 AM
1995 F150 Custom Wiring nine5flareside 1992-1996 Ford F150
10 November 11th, 2010 07:16 AM
1995 , f150
