Quantcast Starter wiring routing issues. - Ford Truck Club Forum
Old March 8th, 2015, 02:17 PM
Fordtruck1992's Avatar
Fordtruck1992 Fordtruck1992 is offline
Default Starter wiring routing issues.
It's been two years since I've taken the engine out and the one things I can't remember is where these wires bolt on Click image for larger version
Old March 8th, 2015, 09:22 PM
The closest to the bottom, square ish one, goes to the frame right where that metal line is bolted in. The other end of it that's rounded more goes in a bolt on the starter as a ground.
Not sure on the positive ends, they change for your body style (I'm assuming a 92) compared to mine.
Old March 8th, 2015, 11:04 PM
I get where the ones to the starter go. But mostly forget which holes the grounds mount to. If I remember correctly the two on on the cross member go together could you try and get a pic of yours?
dkenny9 , Fordtruck1992 , glc , harrison28 , JSoko , KC9RFO , ncranchero , Russo2
fuel injected 5.8 vacuum routing BeauxLeachman 1992-1996 Ford Bronco
6 December 20th, 2016 03:07 PM
Starter switch Robert 1948-1983 Ford F100
2 July 10th, 2013 06:01 AM
Starter Difference's BigBlue79 Garage Talk: Shop Class 101 0 December 22nd, 2012 12:19 PM
Starter problems Booba5185 1973-1991 Ford F150
8 August 17th, 2012 09:15 AM
need vacume line routing diagram for 91 f350 7.5l engine w/auto trans charlie Garage Talk: Shop Class 101 1 March 5th, 2011 09:39 PM
issues , routing , starter , wiring
