Quantcast help with a GM hei on 351w - Ford Truck Club Forum
Ford Truck Club Forum > FORD BRONCO | BRONCO II > 1980-1986 Ford Bronco
Old December 31st, 2015, 11:41 PM
tmace's Avatar
tmace tmace is offline
Exclamation help with a GM hei on 351w
a buddy of mine just got a gm style distributor and has gotten it installed to replace the old corroded one. the issue we are having is that neither of us had remembered to write down the firing order or the distributor position before the swap, so is there anyone who has also done this swap and can provide pics? a crude drawing would also suffice for the time being. i've came across a few different firing orders and none of them worked so i'm kinda stuck. if any vehicle info is needed its an 83 bronco 5.8L with an automatic. ill try to provide as much detail as possible before the vehicle is towed tomorrow.
Old January 1st, 2016, 11:51 AM
Old January 1st, 2016, 12:33 PM
tmace's Avatar
Tried that and still nothing
Old January 1st, 2016, 02:40 PM
try this if it's got a rotor
if your sure the dist. is in correct
bring #1 up to TDC on compression (both valves closed)
rotor is now pointing to the #1 position on dist.
according to the dist. above my #1 is at the #2 position
Old January 1st, 2016, 03:20 PM
tmace's Avatar
I'll have to start from scratch then. I'm pretty sure it's the fact we aren't on TDC for cylinder 1 but the cold isn't helping when I try to rotate the motor
Old January 2nd, 2016, 12:46 AM
Pull the spark plugs, then the engine is easy to turn over with a socket and breaker bar on the crank pulley bolt. Also, use the timing marks to help you find TDC, they only line up when #1 is at TDC, you just have to determine if it's on the compression stroke or the exhaust stroke.
BornBlu , FXRS , glc , harrison28 , JSoko , Thesmanman , tmace
351W Swap IrishKRO 1973-1991 Ford F150
19 October 24th, 2017 01:21 PM
351w Heads BigBlue79 Garage Talk: Engine & Drivetrain 11 February 17th, 2015 08:54 AM
351W Build IrishKRO Garage Talk: Engine & Drivetrain 28 April 16th, 2014 08:27 PM
351w vs 351c 4v/2v RoadHawg 1992-1996 Ford F150
14 November 23rd, 2013 09:23 AM
84-87 351W H.O. Information nflfreak43 1973-1991 Ford F150
3 March 5th, 2013 12:07 AM
351w , hei
