Quantcast F350 Brake conversion - Ford Truck Club Forum
Old May 13th, 2013, 03:22 PM
The Frankster's Avatar
The Frankster The Frankster is offline
Images: 6
Liked 12 Times in 9 Posts
Default F350 Brake conversion
I've got everything I need and I'm ready to do the swap, but I've had a concern that the lines to the master cylinder won't line up. I was in the yard today and measured a F350 and a 150 and I come up with the f350 sticking one inch further out than the 150. My view of this is, you may be able to pull lines forward one inch but you will not be able to use bracket that holds lines that is mounted on the inside were m/c is bolted to booster. I know you've done this Booba, can you give me more clarification on this?
1993 F150 XLT, 5.8 with E40D, Tow and Handling Package. Fully loaded from factory as truck was special order. Mods: Extang Snap on bed cover. 2" drop in rear, Six Liter Tuneup, NOS 66-72 Ford Air Foil Antenna, Planet Auto Red Ford Oval (grille). Diamond Clear Headlight Package, Bumper Guards, F350 Brake Conversion, Slotted/Drilled Front Rotors, 3 row alum radiator with Mk VIII elec fan. and much more to come!
Old May 13th, 2013, 04:00 PM
The booster itself is the difference in length, so the bracket that holds the lines is in the same place (relative to where the lines go into the master cylinder). My lines lined right up, no problem.
This is before I pulled the booster back off to paint it, you can kinda see the bracket:
Old May 13th, 2013, 07:24 PM
Images: 6
I got that Booba. I know the 150 booster has somewhat of a mounting bracket were the 350 don't. That one inch difference still has me puzzled.
Old May 13th, 2013, 08:24 PM
I'm not sure I know what bracket you are talking about then, do you have a pic?
Here's the 2 boosters next to each other:
Old May 13th, 2013, 10:31 PM
Images: 6
Its just the bulge of the 150 booster. In carport, just sorta looking at a glance I would think it had a bracket. So my mistake. Looking at the photo your last post , just messes with the part of my brain that can't see the forest for trees, how the hard lines to m/c are going to match up. The photo makes it seem there is more than an inch difference.
Old May 14th, 2013, 06:06 PM
Images: 6
Ahhhhhhhhhhhhh, I see said the blind man. I did not realize that once lines were undone from m/c and the bracket, that they would have so much flexibility. Well job is done and I haven't got to do any hard braking, I had a bunch of stuff in back and didn't want to through it all up front but I'm still impressed. Waiting for my champion radiator(was at FedEx Memphis on sat) and I'll get that, mk viii fan and rjm 160 amp installed and then do my headlight harness from rjm which I got today and I think next on the list will be the sag ps swap. I promise Booba, I was not not trying to be hard headed or doubt you. As I said, Now I see. Thanks
Old May 14th, 2013, 08:12 PM
Glad to hear it worked out great, don't worry about doubting me lol. I've been wrong many times and will be wrong even more. If you need help with any of your other mods, let me know. I've done everything on your to do list.
Old May 15th, 2013, 10:21 AM
Images: 6
Thanks Booba. You know I wasn't trying to say you were wrong, I had no idea of the flexibility of the lines. If I had undone one in the yard, I'd had no problem. It was time to change m/c anyway. It was leaking from plunger. But I've been lax at keeping the truck clean and really give things a hard look. Ford in oct 2010, said the brakes were due and they made it this long. They also said I needed cruise module and brake switch so cruise would work, but just replacing the module and it worked fine. Have a great day, and I probably will have some questions.
(View-All Members who have read this thread : 12
ASwaff400 , bikertrash3531 , Booba5185 , Daryl56296 , glc , Hazzardousmat , JSoko , michaelsnodgrass18 , Russo2 , Scorekeeper58 , The Frankster , TwoSpeed
LMC Truck: Shortbed Conversion [S7 Ep. 3-1] Gearz Gearz 0 March 15th, 2013 11:16 AM
F350 brake booster,m/c and wheel cylinder The Frankster 1992-1996 Ford F150
22 November 5th, 2012 03:09 PM
80-96 F-150\Bronco Brake Booster Replacement\F350 Swap Booba5185 Garage Talk: Shop Class 101 30 October 12th, 2012 12:03 AM
HO roller conversion Booba5185 1973-1991 Ford F150
151 July 29th, 2012 01:01 PM
Np203 conversion kit zmr2010 1992-1996 Ford F150
7 February 7th, 2011 12:11 AM
brake , conversion , f350
