Quantcast 04 Plug change.... - Ford Truck Club Forum
Old October 1st, 2009, 01:28 PM
pete59edsel's Avatar
Images: 101
Liked 6 Times in 6 Posts
Default 04 Plug change....
People, please read the TSB on removing the plugs from our 5.4 motors before attempting to change them, if not you will have a hell of a time and will need to buy the Lisle tool. Helped a buddy, for free, to finish his, he broke all but 1 and then came and got me, I ask him if he read the TBS and he said what? We got it with the Lisle tool, and without it you will also have them break. I had mine changed at around 75000 with none breaking, his had 81000 and all but 1 broke, here are some pic for your viewing pleasure.
Yes these plugs are a bear, but if done right you will have good results.
Again, please read the TSB on removing our plugs...it is on this site!
Old October 1st, 2009, 01:32 PM
it really makes you wonder what the engineers were thinking when they designed this type of plug.
nice post....pictures were a nice touch....i've never actually seen the aftermath of the plug issue myself
Old October 1st, 2009, 01:37 PM
God, I would never want to go through a broken spark plug. A flush break along the head and I think I would start crying. Fantastic post Pete!
Old October 1st, 2009, 01:39 PM
Images: 101
Thanks man, thing is it is not the threads that have the problem, just look below the threads, see where it is smooth? That is where they get "stuck" and that is why soaking helps alot!! But remember, do not soak to much, they say it could hydrolock...
Hydrolock (short for either hydraulic lock or hydrostatic lock) is a condition of an internal combustion engine in which an incompressible liquid has been introduced into its cylinder resulting in the immobilization of the engine's pistons. The liquid causing this malfunction is often water, hence the prefix "hydro-". Internal combustion engines must compress air to work efficiently and this works because gases can be compressed. Liquids do not compress so if a volume of liquid greater than the volume of the combustion chamber at its minimum (top of the piston's stroke) enters the combustion chamber then the piston cannot complete its travel. Either the engine must stop rotating or something must give. The result is often a bent connecting rod or sometimes a cracked cylinder head or block.
I'm sure you guys know what hydrolock meant, but it was a just in case.
Old October 1st, 2009, 01:40 PM
Images: 101
One last thing, the Lisle tool is a god send, without that where would you be?? Removal of head is where, the engine head that is, not your own....
Old October 1st, 2009, 01:52 PM
I actually had no idea what hydrolock. Thanks for the serious info. I hope some members will find this to be very usefull. Now I have to look up the Lisle tool and see what the heck that is!
Old October 1st, 2009, 01:55 PM
Ok I looked it up and see that Lisle is a tool manufacturer. Any way of getting an exact model number on that tool to further help the members out who may have this issue?
Old October 1st, 2009, 01:57 PM
I think this may be it:
http://www.denlorstools.com/home/dt1...65600_alt.html
Old October 1st, 2009, 02:09 PM
Images: 101
Correct, you nailed it....that is the bad boy!
Old October 1st, 2009, 02:23 PM
Scotts Black FX4's Avatar
Images: 40
There is also this....
http://www.denlorstools.com/home/dt1...lug_remov.html
which is a tad pricey, hence why there is this...
http://www.denlorstools.com/autoblog...pecialty-tool/
05f150xlt , JSoko , nismo972 , Stone F150
NEW '04-'08 Spark Plug; 4.6 & 5.4 3V JSoko 2004-2008 Ford F150
13 July 15th, 2010 09:59 PM
04-05 Spark Plug Problem 2004FX4F150 Garage Talk: Paint & Detailing 3 March 10th, 2010 03:35 PM
Lisle tool / spark plug remover JSoko Garage Talk: The Tool Depot™ 0 July 19th, 2009 07:34 AM
Spark Plug Removal instructions JSoko Garage Talk: Shop Class 101 3 July 18th, 2009 10:29 PM
5.4 Spark Plug Socket JSoko Garage Talk: The Tool Depot™ 0 July 18th, 2009 01:06 PM
change , plug
