Quantcast RPM issue & starting issue - Ford Truck Club Forum
Old December 2nd, 2012, 07:44 PM
rusty001's Avatar
rusty001 rusty001 is offline
Default RPM issue & starting issue
Hi,
Has anyone ever had this problem? When I pull away from a stop and shift into second gear (or shifting into any gear) I push the clutch in but the RPM's do not drop. As a result I get a clunk when the clutch engages. Doesn't matter what the RPM's are. It does it at any RPM range
My starting issue is intermittent. When the truck seems to be at an incline with the nose higher than the back it won't start. Had it towed to a garage twice and it started fine both times when it came off the tow truck. As a result the machanic can't tell me anything. Can anyone help me?
Old December 2nd, 2012, 08:00 PM
Without knowing what engine you are working with, I'd start with the TPS. Tell me what engine you are working with and I'll tell you how to test the TPS. If the TPS tests good, manually move the throttle linkage and make sure it's not getting hung up.
BigBlue79 , bikertrash3531 , Booba5185 , michaelsnodgrass18 , rikard , Russo2 , rusty001
Wiring issue JimGreen 2009-2014 Ford F150
4 June 26th, 2013 10:24 PM
Running Issue RichardGunz 1992-1996 Ford F150
8 October 31st, 2012 11:04 AM
Lighting issue txweslawyer 1999-2007 Ford F250 | F350
1 October 19th, 2012 10:25 AM
Timing chain issue skatebowd 1997-2003 Ford F150
32 April 13th, 2012 11:10 AM
Flooding issue BigBlue79 1973-1991 Ford F150
26 October 17th, 2011 02:36 PM
issue , rpm , starting
