Quantcast Shifting problem? - Ford Truck Club Forum
Old January 9th, 2012, 12:09 AM
russ94's Avatar
russ94 russ94 is offline
Default Shifting problem?
OK well i deiced to ditch the bully dog programmer and it was worth it i switched to the edge cs and had no problems until i had my truck re gear down from 3.73 to 4.10 now from 2nd to 3rd the truck bucks hard and has a shimmy but only on power settings! and the problem only occurs when i am floor boarding it. my firmness is at 4 % and i already lowerd the shift point but it still feels like second is to long does any one have an idea?
whould a shift kit help??
Old January 9th, 2012, 08:44 AM
Images: 624
Liked 185 Times in 167 Posts
are you saying that you changed the gear in the rear end
or you just made the change on the programer
Old February 11th, 2012, 08:59 PM
TedC's Avatar
TedC TedC is offline
Images: 151
I had the exact same problem with mine (Gryphon CS). Let me try and guess what you did:
you choose a level - then when it asks if you want to customize it - you say yes, right? because you need to put in the number for the new gear ratio or tire sizes or whatever...
If you did this and skipped through the other settings and just accepted the default - when in WOT (wide open throttle) - and the truck wants to upshift - the whole thing shudders and sputters. The best explanation I can put to it is it looks like your just starting to learn how to drive a stick shift and haven't gotten the hang of clutch and gas.
If you want to customize - your going to need to know every setting for every item on the list. there's some problem with edge's "default" values chosen when you say customize.
Old February 11th, 2012, 10:09 PM
A shift kit would just make the trans bang through the gears. Probably going to give you the same feeling you are feeling now. Most transmissions are built to have slippage so that the trans shifts smoother... shift kits create firmer shifts. Automatics...
As far as the tuner, well you got me there! I'm an OBD I kinda guy!
1983302 , 460big_boy , Booba5185 , DoubleDee , Frankie , HawaiianF150 , jleerider , js1990 , JSoko , Monster , nine5flareside , russ94 , Russo2 , TedC , vinniejura
tailgate problem tam85 2011-2016 Ford F250 | F350
8 November 6th, 2013 09:03 AM
3 July 21st, 2013 10:10 PM
LED Tail Light Problem hmrhed1 2008-2010 Ford F250 | F350
14 October 20th, 2010 03:46 PM
Strange HID problem 2004FX4F150 2004-2008 Ford F150
20 February 22nd, 2010 06:29 PM
problem , shifting
