Quantcast Do you have the dreaded P0171 & P0174 code? - Ford Truck Club Forum
Ford Truck Club Forum > RANGER | MAZDA-B > 1998-2000 Ford Ranger
Old February 11th, 2018, 12:10 AM
DoubleDee's Avatar
DoubleDee DoubleDee is offline
Images: 669
Default Do you have the dreaded P0171 & P0174 code?
Has your check engine light been on for a while? Does you Ranger drink more fuel than it used to? Have you gone to the auto store to get your check engine light/OBDII scanned to find out it has a running lean bank 1 and bank 2 issue? If you have a 4.0, I have a few answers and a solution for you!
I have found a wonderful website that addresses these exact codes. And more specifically if you have both. Possible problems include:
PCV hose leak
Intake Manifold Gasket leak
Fuel pump going, but not gone yet
MAF sensor dirty
Exhaust leak before the pre catalytic converter O2 sensors
Bad pre catalytic converter O2 sensors
Here's the link for Troubleshooting P0171 And P0174 Ford 4.0L V6
I ended up finding that my lower intake manifold gasket was shot and had to be replaced.
Double(. Y .)Dee
SSG, TXARNG
OIF III ('05) & OIF VIII ('10)
Least knowledgeable when it comes to the whirly, spinny things.
How To Use The FTC Gallery
Check out the Truck of the Month forum and vote!
2004-2008 F-150 Specific How To's:
VIN Decoder
Gotts Mod - 4.6L (5.4L similar)
Big 3 Upgrade
Seat Removal
Interior Door Disassembly SCrew (RCab/SCab similar)
Interior Trim/Carpet Removal
"Fighting is not handing out cookies, it's gunfire and rockets, and there will be casualties." - Haji Khalifa Mohammad Shah
harrison28 (February 12th, 2018)
Old February 19th, 2018, 10:02 AM
Images: 243
Liked 31 Times in 31 Posts
welcome back
« A Wobbly spinning wheel. | There is no next thread »
(View-All Members who have read this thread : 9
aaronbost , CharlieM , DoubleDee , F100Chief , glc , harrison28 , skatebowd , Sman , vuongngho33016
Code 327 help chesster51 1992-1996 Ford F150
11 February 5th, 2015 09:15 PM
Error codes P0171, P0341, P0346 nukemeanster 2009-2014 Ford F150
5 June 27th, 2013 11:10 PM
the time has come, dreaded repair michaelsnodgrass18 1992-1996 Ford F150
10 September 21st, 2012 12:08 AM
Investors bracing for dreaded 'September effect' BigT67 General Discussion
0 August 31st, 2010 08:34 PM
DTCs P0171/0174/1000 2004FX4F150 2004-2008 Ford F150
7 March 13th, 2010 11:37 AM
code , dreaded , lean , p0171 , p0174 , ranger running lean
