Quantcast Smog pump R & R on 1996 F-150 4.9L - Ford Truck Club Forum
Old February 27th, 2018, 08:14 PM
Wineman262's Avatar
Wineman262 Wineman262 is offline
Default Smog pump R & R on 1996 F-150 4.9L
I joined club today as was having problem R & R ing my smog pump. Ford uses a sliding bushing on top thru bolt holding smog pump onto mounting bracket as well as an additional bolt on bottom rear side of pump. I was having a problem fitting pump into top space between bushing and mounting bracket. SOLUTION: I put a bolt thru sliding bushing long enough to accommodate a 9/16 quarter inch socket. I then tightened bold down enough to pull sliding bushing towards front of mounting bracket. This allowed the smog pump's top mounting to slide in. Then when tightening down the mounting "thru bolt" into mounting bracket it brought the sliding busing to the proper distance to align smog pump with serpentine belt pathway. I posted this because I have not seen this procedure discussed anywhere as far as dealing with these sliding bushings or spacer bushings. Hope this helps someone else
Old February 28th, 2018, 02:31 PM
Thanks for the tip. I'm sure somebody will be asking the same question someday, and they will find your cure for their problem.
glc , harrison28 , sandro , TXFM , Wineman262
Smog Pump removal G-Dub 1948-1986 Ford F250 | F350
1 July 14th, 2017 08:28 AM
89 f-250 smog pump hoses star2serv 1987-1991 Ford F250 | F350
1 July 30th, 2016 09:57 AM
Smog pump Sclove ford 1992-1996 Ford F150
1 October 25th, 2015 12:27 PM
smog air pump ? muddy1977 1973-1991 Ford F150
7 October 31st, 2013 05:02 PM
How To: Replace A.I.R (Smog) Pump 92-96 V8s bikertrash3531 Garage Talk: Shop Class 101 18 March 30th, 2013 07:22 PM
1996 , 49l , f150 , pump , smog
