Quantcast Ford, Explorer, Brakes - Ford Truck Club Forum
Ford Truck Club Forum > ALL OTHER FORD MODELS > Ford Explorer
Old August 21st, 2012, 12:09 AM
gtxmn1214's Avatar
gtxmn1214 gtxmn1214 is offline
Default Ford, Explorer, Brakes
I need some info on bleeding the brakes on a 2006 ford explorer.i have been told that the engine should not be running when bleeding is this correct?
I am doing this because the brake pedal if not pushed for appx.3-4 minutes the pedal will go almost to the floor but still has stopping power and when i let off and hit the pedal again i have a full brake pedal so any suggestions on what else could be going on with the brakes.this vehicle has 92k plus miles bought new by myself and no issues at all until this has always been serviced regularly on time.
All help appreciated. Thanks arnett
Redwardsray (November 29th, 2018)
Old August 21st, 2012, 10:11 AM
DoubleDee's Avatar
DoubleDee DoubleDee is offline
Images: 669
You're correct about the engine not running when bleeding.
That whole brake pedal to the floor and all, I have no idea.
Double(. Y .)Dee
SSG, TXARNG
OIF III ('05) & OIF VIII ('10)
Least knowledgeable when it comes to the whirly, spinny things.
How To Use The FTC Gallery
Check out the Truck of the Month forum and vote!
2004-2008 F-150 Specific How To's:
VIN Decoder
Gotts Mod - 4.6L (5.4L similar)
Big 3 Upgrade
Seat Removal
Interior Door Disassembly SCrew (RCab/SCab similar)
Interior Trim/Carpet Removal
"Fighting is not handing out cookies, it's gunfire and rockets, and there will be casualties." - Haji Khalifa Mohammad Shah
Old August 21st, 2012, 11:58 AM
It's possible that it needs to bled, so I'd start there, but it could also be the master cylinder too.
You'll need a helper to bleed the brakes. Have the helper pump the brakes 3 or 4 times and hold pressure on the brake pedal, then loosen the bleeding screw on the drum\disk brakes until either the air comes out of the pedal hit the ground. If the pedal hits the ground, tighten the bleeding screw and have the helper pump the brakes again. If the air comes out (it will almost spit at you so be ready) tighten the bleeding screw and move on to the next tire. Do this for all 4 tires, starting at the tire that is farthest away from the mast cylinder and work your way back. This means bleed the back passsnger, then the back driver, then the front passenger, then the front driver.
Good luck.
Old August 21st, 2012, 01:54 PM
Also check for defective lines!
Old August 21st, 2012, 02:37 PM
Images: 624
Liked 185 Times in 167 Posts
check these out I found on the site useing SEARCH, click on the safe links below
http://www.fordtruckclub.net/forum/s...t=bleed+brakes
2 good links in this one s post #2 http://www.fordtruckclub.net/forum/s...t=bleed+brakes
Old August 23rd, 2012, 12:01 AM
gtxmn1214's Avatar
Smile 2006 Ford Explorer brake problem
Hello,
i would like to thank all for the reply to my post regarding my
2006 explorer brake issue.
I will try these steps tomorrow and let you all know how it turns out.
Thanks again
gtxmn1214
BigBlue79 , Booba5185 , DoubleDee , gtxmn1214 , JSoko , Klitch , Red91 , Redwardsray
Ford Releases Pricing on All-New Ford Explorer, Base Starts at $28,995 Bates88 Garage Talk: General Tech Talk 0 July 28th, 2010 05:45 PM
With Explorer, Ford hopes to redefine SUV BigT67 General Discussion
0 July 26th, 2010 09:27 PM
Ford Teases 2011 Explorer Bates88 Garage Talk: General Tech Talk 0 June 11th, 2010 04:53 PM
Ford Plans Police-Spec SUV Based on New Explorer Bates88 Garage Talk: General Tech Talk 0 May 26th, 2010 01:44 PM
1999 Ford Explorer Sport 2dr For SALE RedHot150 Vehicles For Sale
4 March 4th, 2010 03:39 PM
brakes , explorer , ford
